[petsc-users] Access to factored matrix.
De Groof, Vincent Frans Maria Vincent.De-Groof at uibk.ac.at
Fri Jun 20 06:24:51 CDT 2014
I'm looking for a way to access the factor of a matrix to be able to change it. I'm using CHOLMOD for the factorization which uses the cholmod_factor object. The data contained in this object is basically what I want to get access to. Ideally, I'll be able to use the petsc-functions as is. Make some changes to the factored matrix and afterwards continue usingthe petsc-functions.
Do you have any suggestions how this could be done? I had a look at PCFactorGetMatrix, but the matrix does not seem to contain numerical data of the factor.
thanks,
Vincent
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140620/23ed00f4/attachment.html>
