[petsc-users] Getting Eigenvectors from a SLEPc run (in python)
Alex Eftimiades
alexeftimiades at gmail.com
Mon Jun 9 15:33:44 CDT 2014
Thanks.
For anyone who reads this, the correct code looks like this:
E.solve()
vals = []
vecs = []
for i in range(E.getConverged()):
val = E.getEigenpair(i, xr, xi)
vals.append(val)
vecs = [complex(xr0, xi0) for xr0, xi0 in zip(xr.getArray(),
xi.getArray())]
vals = asarray(vals)
vecs = asarray(vecs).T
On 06/09/2014 02:58 PM, Jose E. Roman wrote:
> El 09/06/2014, a las 20:45, Alex Eftimiades escribió:
>> Hi
>> I am trying solve a sparse generalized Hermitian matrix eigenvalue problem. I am trying to use slepc4py to get both the eigenvalues and eigenvectors, but I am unable to get the eigenvectors. Instead, I keep getting None. Do you have any example code that can do this? I copied the code I have tried below.
>> Thanks,
>> Alex Eftimiades
>> xr, tmp = A.getVecs()
>> xi, tmp = A.getVecs()
>> # Setup the eigensolver
>> E = SLEPc.EPS().create()
>> E.setOperators(A,M)
>> E.setDimensions(50, PETSc.DECIDE)
>> E.setWhichEigenpairs("SM")
>> E.solve()
>> vals = []
>> vecs = []
>> vecr, veci = E.getEigenvector(i, xr, xi)
>> vals.append(val)
>> vecs.append(complex(vecr, veci))
> Eigenvectors are not obtained as return values. Instead, the arguments of getEigenvector() are mutable, so after the call they contain the eigenvector.
> Jose
