[petsc-users] Performance question using seq Mat and Vec
Brian Yang jyang29 at uh.edu
Thu Jul 31 16:43:26 CDT 2014
I found one thing, as long as I don't destroy the vector that holds the
solution from KSPGetSolution, I could successfully destroy all other
objects (including KSP) for each panel.
On Thu, Jul 31, 2014 at 4:36 PM, Brian Yang <jyang29 at uh.edu> wrote:
> Here's the message (all the nodes are the same):
> [8]PETSC ERROR:
> [8]PETSC ERROR: VecDestroy() line 539 in src/vec/vec/interface/vector.c
> [8]PETSC ERROR: KSPReset() line 740 in src/ksp/ksp/interface/itfunc.c
> [8]PETSC ERROR: KSPDestroy() line 783 in src/ksp/ksp/interface/itfunc.c
> [6]PETSC ERROR: --------------------- Error Message
> [6]PETSC ERROR: Invalid argument!
> [6]PETSC ERROR: Wrong type of object: Parameter # 1!
> [6]PETSC ERROR:
> [6]PETSC ERROR: Petsc Release Version 3.4.3, Oct, 15, 2013
> [6]PETSC ERROR: See docs/changes/index.html for recent updates.
> [6]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
> [6]PETSC ERROR: See docs/index.html for manual pages.
> [6]PETSC ERROR:
> On Thu, Jul 31, 2014 at 4:31 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>> On Jul 31, 2014, at 3:24 PM, Brian Yang <jyang29 at uh.edu> wrote:
>> > Hi all,
>> > Here's an abstract of the problem,
>> > I got src and rec, they are 3D images with the same size, say Z, X, Y.
>> > We call one (Z, X) is a panel and then there's Y panels for both src
>> and rec. BTW, they hold complex numbers.
>> > For example, for the first panel (always process the same panel) of src
>> and rec:
>> > Take the first panel of src as our A (20x20),
>> > take the first column of first panel of rec as our b (20x1),
>> > solve the linear system and get x (20x1),
>> > go to next column of the first panel of rec until finish this panel,
>> > assemble all the solution x column by column (20x20).
>> > After finishing the first panel of src and rec, go to next... repeat.
>> > Hope I explained well of my problem. I used SeqDense matrix for A and
>> Seq vector for b.
>> > Here's the flow,
>> > - start
>> > - all the nodes will share all the Y panels, each node will get part of
>> them
>> > - each node will read in its own part of src and rec images
>> > - for each node, take a panel of src and rec
>> > - create Mat and Vec, fill them
>> > - create KSP and solve by lsqr
>> > - get the solution
>> > - destroy all the petsc object, A, b, x (destroying KSP will give me
>> error here!)
>>     If you do not destroy the KSP then the other objects won't get
>> destroyed (since the KSP reference counts them). You need to determine why
>> the KSP cannot be destroyed. What is the error message? Run with valgrind?
>> > - repeat for the next panel
>> > Here's the time (seconds) output from node 2 (random choice):
>> >                            entire time for this panel
>>  solving time
>> >  processing panel           1 time=  3.2995000E-02 solver=
>>  3.0995002E-02
>> >  processing panel           2 time=  3.5994001E-02 solver=
>>  3.4995001E-02
>> >  processing panel           3 time=  3.9994001E-02 solver=
>>  3.8994007E-02
>> >  processing panel           4 time=  4.4993997E-02 solver=
>>  4.3993995E-02
>> >  processing panel           5 time=  4.8991993E-02 solver=
>>  4.6992987E-02
>> >  processing panel           6 time=  5.4991007E-02 solver=
>>  5.3991005E-02
>> >  processing panel           7 time=  5.8990985E-02 solver=
>>  5.7990998E-02
>> >  processing panel           8 time=  6.3990027E-02 solver=
>>  6.1990023E-02
>> >  processing panel           9 time=  6.8989992E-02 solver=
>>  6.6990018E-02
>> >  processing panel          10 time=  7.3989004E-02 solver=
>>  7.1989000E-02
>> >  processing panel          11 time=  7.7987969E-02 solver=
>>  7.6987982E-02
>> >  processing panel          12 time=  8.1988037E-02 solver=
>>  7.9988003E-02
>> >  processing panel          13 time=  8.8985980E-02 solver=
>>  8.6987019E-02
>> >  processing panel          14 time=  9.4985008E-02 solver=
>>  9.2984974E-02
>> >  processing panel          15 time=  0.1009850     solver=
>>  9.8985016E-02
>> >  processing panel          16 time=  0.1119831     solver=  0.1099830
>> >  processing panel          17 time=  0.1269809     solver=  0.1239820
>> >  processing panel          18 time=  0.1469780     solver=  0.1439790
>> >  processing panel          19 time=  0.1709731     solver=  0.1669741
>> >  processing panel          20 time=  0.1909720     solver=  0.1869720
>> >  processing panel          21 time=  0.2019690     solver=  0.1979700
>> >  processing panel          22 time=  0.2239659     solver=  0.2199659
>> >  processing panel          23 time=  0.2369640     solver=  0.2319648
>> >  processing panel          24 time=  0.2499621     solver=  0.2449629
>> >  processing panel          25 time=  0.2709589     solver=  0.2659600
>> >  processing panel          26 time=  0.2869561     solver=  0.2829571
>> >  processing panel          27 time=  0.3129530     solver=  0.3059540
>> >  processing panel          28 time=  0.3389480     solver=  0.3329499
>> >  processing panel          29 time=  0.3719430     solver=  0.3649440
>> >  processing panel          30 time=  0.3949399     solver=  0.3879409
>> >  processing panel          31 time=  0.4249353     solver=  0.4169374
>> >  processing panel          32 time=  0.4549308     solver=  0.4469318
>> >  processing panel          33 time=  0.4859262     solver=  0.4759283
>> >  processing panel          34 time=  0.5119228     solver=  0.5019240
>> >  processing panel          35 time=  0.5449171     solver=  0.5349178
>> >  processing panel          36 time=  0.5689130     solver=  0.5579152
>> >  processing panel          37 time=  0.5959096     solver=  0.5849104
>> >  processing panel          38 time=  0.6199055     solver=  0.6079073
>> > You could see the time for solving the panels are increasing all the
>> time. The panel number here is the local one. If I start to solve from
>> panel 40 (random choice):
>> >  processing panel          40 time=  5.5992007E-02 solver=
>>  5.1991999E-02
>> >  processing panel          41 time=  9.1986001E-02 solver=
>>  9.0986013E-02
>> >  processing panel          42 time=  0.1309800     solver=  0.1299810
>> >  processing panel          43 time=  0.1719730     solver=  0.1709740
>> >  processing panel          44 time=  0.2119681     solver=  0.2109680
>> >  processing panel          45 time=  0.2529620     solver=  0.2519621
>> >  processing panel          46 time=  0.2919550     solver=  0.2909551
>> >  processing panel          47 time=  0.3319499     solver=  0.3309500
>> >  processing panel          48 time=  0.3719430     solver=  0.3709428
>> >  processing panel          49 time=  0.4129372     solver=  0.4109371
>> >  processing panel          50 time=  0.4529319     solver=  0.4509320
>> >  processing panel          51 time=  0.4929240     solver=  0.4909239
>> >  processing panel          52 time=  0.5339203     solver=  0.5319204
>> >  processing panel          53 time=  0.5779119     solver=  0.5759130
>> >  processing panel          54 time=  0.6199059     solver=  0.6179061
>> >  processing panel          55 time=  0.6648979     solver=  0.6628990
>> >  processing panel          56 time=  0.7248902     solver=  0.7218900
>> >  processing panel          57 time=  0.7938790     solver=  0.7908792
>> >  processing panel          58 time=  0.8728676     solver=  0.8698678
>> >  processing panel          59 time=  0.9778509     solver=  0.9748516
>> >  processing panel          60 time=   1.125830     solver=   1.122829
>> >  processing panel          61 time=   1.273806     solver=   1.268806
>> >  processing panel          62 time=   1.448780     solver=   1.444779
>> >  processing panel          63 time=   1.647749     solver=   1.643749
>> >  processing panel          64 time=   1.901712     solver=   1.896712
>> >  processing panel          65 time=   2.143673     solver=   2.138674
>> >  processing panel          66 time=   2.437630     solver=   2.431629
>> >  processing panel          67 time=   2.744583     solver=   2.736586
>> >  processing panel          68 time=   3.041536     solver=   3.035538
>> > The trend is the same, the time is increasing and also starts from a
>> very quick one.
>> > Since I have thousands of panels for src and rec, the execution time is
>> unbearable as it goes.
>> > So I am wondering whether I used the right method? or there's memory
>> issue?
>> > Thanks.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140731/4206ebce/attachment.html>
