[petsc-users] Performance question using seq Mat and Vec
Brian Yang
jyang29 at uh.edu
Thu Jul 31 16:36:55 CDT 2014
Here's the message (all the nodes are the same):
[8]PETSC ERROR:
[8]PETSC ERROR: VecDestroy() line 539 in src/vec/vec/interface/vector.c
[8]PETSC ERROR: KSPReset() line 740 in src/ksp/ksp/interface/itfunc.c
[8]PETSC ERROR: KSPDestroy() line 783 in src/ksp/ksp/interface/itfunc.c
[6]PETSC ERROR: --------------------- Error Message
[6]PETSC ERROR: Invalid argument!
[6]PETSC ERROR: Wrong type of object: Parameter # 1!
[6]PETSC ERROR:
[6]PETSC ERROR: Petsc Release Version 3.4.3, Oct, 15, 2013
[6]PETSC ERROR: See docs/changes/index.html for recent updates.
[6]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
[6]PETSC ERROR: See docs/index.html for manual pages.
[6]PETSC ERROR:
On Thu, Jul 31, 2014 at 4:31 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> On Jul 31, 2014, at 3:24 PM, Brian Yang <jyang29 at uh.edu> wrote:
> > Hi all,
> > Here's an abstract of the problem,
> > I got src and rec, they are 3D images with the same size, say Z, X, Y.
> > We call one (Z, X) is a panel and then there's Y panels for both src and
> rec. BTW, they hold complex numbers.
> > For example, for the first panel (always process the same panel) of src
> and rec:
> > Take the first panel of src as our A (20x20),
> > take the first column of first panel of rec as our b (20x1),
> > solve the linear system and get x (20x1),
> > go to next column of the first panel of rec until finish this panel,
> > assemble all the solution x column by column (20x20).
> > After finishing the first panel of src and rec, go to next... repeat.
> > Hope I explained well of my problem. I used SeqDense matrix for A and
> Seq vector for b.
> > Here's the flow,
> > - start
> > - all the nodes will share all the Y panels, each node will get part of
> them
> > - each node will read in its own part of src and rec images
> > - for each node, take a panel of src and rec
> > - create Mat and Vec, fill them
> > - create KSP and solve by lsqr
> > - get the solution
> > - destroy all the petsc object, A, b, x (destroying KSP will give me
> error here!)
> If you do not destroy the KSP then the other objects won't get
> destroyed (since the KSP reference counts them). You need to determine why
> the KSP cannot be destroyed. What is the error message? Run with valgrind?
> > - repeat for the next panel
> > Here's the time (seconds) output from node 2 (random choice):
> > entire time for this panel solving
> time
> > processing panel 1 time= 3.2995000E-02 solver= 3.0995002E-02
> > processing panel 2 time= 3.5994001E-02 solver= 3.4995001E-02
> > processing panel 3 time= 3.9994001E-02 solver= 3.8994007E-02
> > processing panel 4 time= 4.4993997E-02 solver= 4.3993995E-02
> > processing panel 5 time= 4.8991993E-02 solver= 4.6992987E-02
> > processing panel 6 time= 5.4991007E-02 solver= 5.3991005E-02
> > processing panel 7 time= 5.8990985E-02 solver= 5.7990998E-02
> > processing panel 8 time= 6.3990027E-02 solver= 6.1990023E-02
> > processing panel 9 time= 6.8989992E-02 solver= 6.6990018E-02
> > processing panel 10 time= 7.3989004E-02 solver= 7.1989000E-02
> > processing panel 11 time= 7.7987969E-02 solver= 7.6987982E-02
> > processing panel 12 time= 8.1988037E-02 solver= 7.9988003E-02
> > processing panel 13 time= 8.8985980E-02 solver= 8.6987019E-02
> > processing panel 14 time= 9.4985008E-02 solver= 9.2984974E-02
> > processing panel 15 time= 0.1009850 solver= 9.8985016E-02
> > processing panel 16 time= 0.1119831 solver= 0.1099830
> > processing panel 17 time= 0.1269809 solver= 0.1239820
> > processing panel 18 time= 0.1469780 solver= 0.1439790
> > processing panel 19 time= 0.1709731 solver= 0.1669741
> > processing panel 20 time= 0.1909720 solver= 0.1869720
> > processing panel 21 time= 0.2019690 solver= 0.1979700
> > processing panel 22 time= 0.2239659 solver= 0.2199659
> > processing panel 23 time= 0.2369640 solver= 0.2319648
> > processing panel 24 time= 0.2499621 solver= 0.2449629
> > processing panel 25 time= 0.2709589 solver= 0.2659600
> > processing panel 26 time= 0.2869561 solver= 0.2829571
> > processing panel 27 time= 0.3129530 solver= 0.3059540
> > processing panel 28 time= 0.3389480 solver= 0.3329499
> > processing panel 29 time= 0.3719430 solver= 0.3649440
> > processing panel 30 time= 0.3949399 solver= 0.3879409
> > processing panel 31 time= 0.4249353 solver= 0.4169374
> > processing panel 32 time= 0.4549308 solver= 0.4469318
> > processing panel 33 time= 0.4859262 solver= 0.4759283
> > processing panel 34 time= 0.5119228 solver= 0.5019240
> > processing panel 35 time= 0.5449171 solver= 0.5349178
> > processing panel 36 time= 0.5689130 solver= 0.5579152
> > processing panel 37 time= 0.5959096 solver= 0.5849104
> > processing panel 38 time= 0.6199055 solver= 0.6079073
> > You could see the time for solving the panels are increasing all the
> time. The panel number here is the local one. If I start to solve from
> panel 40 (random choice):
> > processing panel 40 time= 5.5992007E-02 solver= 5.1991999E-02
> > processing panel 41 time= 9.1986001E-02 solver= 9.0986013E-02
> > processing panel 42 time= 0.1309800 solver= 0.1299810
> > processing panel 43 time= 0.1719730 solver= 0.1709740
> > processing panel 44 time= 0.2119681 solver= 0.2109680
> > processing panel 45 time= 0.2529620 solver= 0.2519621
> > processing panel 46 time= 0.2919550 solver= 0.2909551
> > processing panel 47 time= 0.3319499 solver= 0.3309500
> > processing panel 48 time= 0.3719430 solver= 0.3709428
> > processing panel 49 time= 0.4129372 solver= 0.4109371
> > processing panel 50 time= 0.4529319 solver= 0.4509320
> > processing panel 51 time= 0.4929240 solver= 0.4909239
> > processing panel 52 time= 0.5339203 solver= 0.5319204
> > processing panel 53 time= 0.5779119 solver= 0.5759130
> > processing panel 54 time= 0.6199059 solver= 0.6179061
> > processing panel 55 time= 0.6648979 solver= 0.6628990
> > processing panel 56 time= 0.7248902 solver= 0.7218900
> > processing panel 57 time= 0.7938790 solver= 0.7908792
> > processing panel 58 time= 0.8728676 solver= 0.8698678
> > processing panel 59 time= 0.9778509 solver= 0.9748516
> > processing panel 60 time= 1.125830 solver= 1.122829
> > processing panel 61 time= 1.273806 solver= 1.268806
> > processing panel 62 time= 1.448780 solver= 1.444779
> > processing panel 63 time= 1.647749 solver= 1.643749
> > processing panel 64 time= 1.901712 solver= 1.896712
> > processing panel 65 time= 2.143673 solver= 2.138674
> > processing panel 66 time= 2.437630 solver= 2.431629
> > processing panel 67 time= 2.744583 solver= 2.736586
> > processing panel 68 time= 3.041536 solver= 3.035538
> > The trend is the same, the time is increasing and also starts from a
> very quick one.
> > Since I have thousands of panels for src and rec, the execution time is
> unbearable as it goes.
> > So I am wondering whether I used the right method? or there's memory
> issue?
> > Thanks.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140731/93efd4c1/attachment-0001.html>
