[petsc-users] same code, different machine, different performance
Jed Brown jed at jedbrown.org
Wed Jul 30 01:28:40 CDT 2014
张国熙 <altriaex86 at gmail.com> writes:
> Hi,all
> Recently I am using SLEPc to solve an sparse eigenvalue problem. I use
> krylov-shur and mumps as solvers.
> My codes work well my corei5 dual core laptop. Compared to my old
> sequential solution ARPACK/UMFPACK, running with 2 process could give me
> 1.3x speedup. However when I install my code on another station with quad
> core CPU, the performance change significantly. My parallel code runs 2-3
> times slower than sequential code.
Run "make streams NPMAX=4" and send the output.
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140730/d64c8880/attachment.pgp>
