[petsc-users] Poor multigrid convergence in parallel
Lawrence Mitchell lawrence.mitchell at imperial.ac.uk
Sat Jul 26 07:03:06 CDT 2014
On 25 Jul 2014, at 21:28, Jed Brown <jed at jedbrown.org> wrote:
> Sorry about not following up.  I also find these results peculiar.
> Lawrence Mitchell <lawrence.mitchell at imperial.ac.uk> writes:
>> So I'm sort of none-the-wiser.  I'm a little bit at a loss as to why
>> this occurs, but either switching to Richardson+SOR or Cheby/SOR with
>> more that one SOR sweep appears to fix the problems, so I might just
>> punt for now.
> What discretization and mesh is this running on?
Bog-standard P1 on a pretty much regularly meshed square domain (i.e. no reentrant corners or bad elements).
> Is there something special about the decomposition with 2 subdomains?
It doesn't look like it, the two subdomains are about the same size.
> Are the Chebyshev estimates far from converging?
So for the two-level problem, if I compute the extremal eigenvalues of the preconditioned operator being used as a smoother I get (approximately):
1 process:
0.019, 1.0
2 processes:
0.016, 1.4
3 processes:
0.016, 1.36
The eigenvalue estimates (from ksp_view) are:
1 process:
0.09, 1.01
2 processes:
0.09, 1.01
3 processes:
0.13, 1.47
When I bump to more levels, the estimates are only bad on two processes on the finest grid.
So for example running with something like (for a 3 level problem):
-pc_type mg -mg_levels_2_ksp_chebyshev_eigenvalues 0.09,1.4
gives me good convergence on two processes where the extremal eigenvalues on the finest grid are:
0.016, 1.39
Cheers,
Lawrence
Desc: Message signed with OpenPGP using GPGMail
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140726/e7f4bf7d/attachment.pgp>
