[petsc-users] Poor multigrid convergence in parallel
Jed Brown jed at jedbrown.org
Fri Jul 25 15:28:14 CDT 2014
Sorry about not following up.  I also find these results peculiar.
Lawrence Mitchell <lawrence.mitchell at imperial.ac.uk> writes:
> So I'm sort of none-the-wiser.  I'm a little bit at a loss as to why
> this occurs, but either switching to Richardson+SOR or Cheby/SOR with
> more that one SOR sweep appears to fix the problems, so I might just
> punt for now.
What discretization and mesh is this running on?  Is there something
special about the decomposition with 2 subdomains?  Are the Chebyshev
estimates far from converging?  Something is funky because if you have a
discretization with good h-ellipticity, reliable convergence should not
be a problem.
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140725/abba9414/attachment.pgp>
