[petsc-users] Petsc/3.5.0 make test failed
Jed Brown jed at jedbrown.org
Fri Jul 25 11:00:43 CDT 2014
Matthew Knepley <knepley at gmail.com> writes:
> On Thu, Jul 24, 2014 at 5:33 PM, Kai Song <ksong at lbl.gov> wrote:
>> Hi Satish,
>> Thanks for the quick response. I attached the make.log in this email, and
>> a quick glance, I didn't see any obvious errors.
> This never built the MUMPS directory, even though you have PETSC_HAVE_MUMPS
> defined. I can see two
> possible reasons for this:
>   1) You distribution as missing files
>   2) You have two copies of PETSc fighting each other here (old PETSC_DIR?)
> Can you make sure you have the file mumps.c in
>   src/mat/impls/aij/mpi/mumps
> Jed, how do we check what make is doing here?
mumps.c should be listed in $PETSC_ARCH/conf/files after the code
generator runs.  Possibly a file system problem or tinkering caused it
to appear up-to-date after reconfiguring?  (Just speculating because we
haven't seen this problem before.)
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140725/e478243a/attachment-0001.pgp>
