[petsc-users] Question about PETSc installs and MPI
Matthew Knepley
knepley at gmail.com
Fri Jul 18 20:58:41 CDT 2014
On Fri, Jul 18, 2014 at 8:16 PM, John Yawney <jyawney123 at gmail.com> wrote:
> Hello,
> I had a question about PETSc installations. On my local computer I
> configured PETSc (v 3.4.2) using the options:
> ./configure --with-cc=mpicc --with-cxx=mpic++ --download-f-blas-lapack
> --download-mpich --download-hypre
> I wrote a test program that defines a vector using DMDAs, computes a dot
> product, exchanges halo elements, and computes a low-order FD derivative of
> the vector. Under my installation of PETSc everything works fine. For
> some reason, when my colleagues run the program, they get segmentation
> fault errors. If they change the y and z boundary types to GHOSTED as well,
> they get the program to run until the end (seg faults at the end though)
> but they get a local value of the dot product. I've attached the main.cpp
> file for this script.
> When they installed their versions of PETSc they didn't use the
> --download-mpich option but instead used either:
> ./configure --download-f-blas-lapack --with-scalar-type=complex
> or with the
> option: --with-mpi-dir=/home/kim/anaconda/pkgs/mpich2-1.3-py27_0
> Could this be causing a problem with the parallelization under PETSc?
I have run your code on my machine up to P=8 and used valgrind. No problems
turned up other
than the fact that you need a "return 0" is missing from main().
If there are still problems, please have them send a stack trace.
Matt
> Thanks for the help and sorry for the long question.
> Best regards,
> John
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140718/e489f9ec/attachment-0001.html>
