[petsc-users] Unable to download elemental
George Pau gpau at lbl.gov
Fri Jul 18 18:38:04 CDT 2014
Hi Barry,
Thanks, that works on my Ubuntu machine.
On Mac however, I have problem with the --with-cxx-dialect=C++11:
Could not determine compiler flag for with-cxx-dialect=C++11, use CXXFLAGS
So, I configure using the following:
./configure --with-cc=mpicc --with-cxx=mpicxx --with-fc=mpif90
--with-mpiexec=mpiexec --CXXFLAGS=-std=c++11 --with-cxx-dialect=C++11
--download-elemental
but, I still get
I tried with just
and it is fine.  I cannot specify --download-elemental without
--with-cxx-dialect=C++11.  Attached is the configure.log again.
George
On Fri, Jul 18, 2014 at 4:06 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>   Sorry, there is an error in our process:
>                     Looking for ELEMENTAL in directory starting with
> elemental
>                     Could not locate an existing copy of elemental:
>                       ['Elemental-0.84-p5’]
> It is looking for a directory that starts with a e while the directory has
> a capital e.
> To fix change the name of the directory
> $PETSC_ARCH/externalpackages/Elemental-0.84-p5 to
> $PETSC_ARCH/externalpackages/elemental-0.84-p5
> Then rerun with the same options as below (PETSc will use the directory
> you’ve renamed automatically).
> Satish,
>     Please check why it is using the elemental instead of the Elemental.
> Why doesn’t it hit our tests?
>   Barry
> On Jul 18, 2014, at 5:50 PM, George Pau <gpau at lbl.gov> wrote:
> > I tried the following:
> --download-elemental --with-cxx-dialect=C++11
> > but get a configure error that says:
> > I tried downloaded the package manually and specifying the path
> -download-elemental=/home/gpau/Downloads/Elemental-0.84-p5.tgz
> > but still get the same error. Attached is the log file for the configure.
> > Thanks,
> > George
> > George Pau
> > Earth Sciences Division
> > Lawrence Berkeley National Laboratory
> > One Cyclotron, MS 74-120
> > Berkeley, CA 94720
> > (510) 486-7196
> > gpau at lbl.gov
> > http://esd.lbl.gov/about/staff/georgepau/
> > <configure.log>
George Pau
Berkeley, CA 94720
(510) 486-7196
gpau at lbl.gov
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140718/98f4a88e/attachment-0001.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140718/98f4a88e/attachment-0001.obj>
