[petsc-users] Unable to download elemental
Fri Jul 18 18:06:42 CDT 2014
  Sorry, there is an error in our process:
                    Looking for ELEMENTAL in directory starting with elemental
                    Could not locate an existing copy of elemental:
                      ['Elemental-0.84-p5’]
It is looking for a directory that starts with a e while the directory has a capital e.
To fix change the name of the directory $PETSC_ARCH/externalpackages/Elemental-0.84-p5 to $PETSC_ARCH/externalpackages/elemental-0.84-p5
Then rerun with the same options as below (PETSc will use the directory you’ve renamed automatically).
Satish,
    Please check why it is using the elemental instead of the Elemental. Why doesn’t it hit our tests?
  Barry
On Jul 18, 2014, at 5:50 PM, George Pau <gpau at lbl.gov> wrote:
> I tried the following:
> ./configure --with-cc=mpicc --with-cxx=mpicxx --with-fc=mpif90 --download-elemental --with-cxx-dialect=C++11
> but get a configure error that says:
> I tried downloaded the package manually and specifying the path -download-elemental=/home/gpau/Downloads/Elemental-0.84-p5.tgz
> but still get the same error. Attached is the log file for the configure.
> Thanks,
> George
> George Pau
> Earth Sciences Division
> Lawrence Berkeley National Laboratory
> One Cyclotron, MS 74-120
> Berkeley, CA 94720
> (510) 486-7196
> gpau at lbl.gov
> http://esd.lbl.gov/about/staff/georgepau/
> <configure.log>
