[petsc-users] Viewing DM Vector stored on Multiple GPUs
Ashwin Srinath
ashwinsrnth at gmail.com
Fri Jul 18 18:29:45 CDT 2014
Thanks so much, Dominic. I'll let you know soon how this branch works for
my code.
Ashwin
On Fri, Jul 18, 2014 at 7:33 PM, Dominic Meiser <dmeiser at txcorp.com> wrote:
> Hi Ashwin,
> I've been working on this issue the last couple of days and wanted to give
> you an update. First off, thanks for the test case. This has helped a lot
> in tracking down the issues. I've created a couple of unit tests based on
> your test case.
> There were several independent bugs that prevented the VecView to work
> with -dm_vec_type cusp. I've fixed some of them in this branch:
> https://bitbucket.org/dmeiser/petsc/branch/fix-cusp-dmda
> Viewing a vector created from a DM should now be possible. For instance
> the test case you provided should work with this branch.
> There are still some issues remaining. DMGlobalToLocalBegin/End and
> DMLocalToGlobalBegin/End are not working. I haven't been able to track
> these down yet. I'll return to this next week.
> Cheers,
> Dominic
> On 06/24/2014 08:15 PM, Ashwin Srinath wrote:
> Hello, petsc-users
> I'm having trouble *viewing* an mpicusp vector. Here's the simplest case
> that reproduces the problem:
> int main(int argc, char** argv) {
> PetscInitialize(&argc, &argv, NULL, NULL);
> DM da;
> Vec V;
> DMDACreate2d( PETSC_COMM_WORLD,
> DM_BOUNDARY_NONE, DM_BOUNDARY_NONE,
> DMDA_STENCIL_BOX,
> 5, 5,
> PETSC_DECIDE, PETSC_DECIDE,
> 1,
> 1,
> NULL, NULL,
> &da);
> DMCreateGlobalVector(da, &V);
> VecSet(V, 1);
> VecView(V, PETSC_VIEWER_STDOUT_WORLD);
> PetscFinalize();
> return 0;
> I get the error:
> [1]PETSC ERROR: Null argument, when expecting valid pointer
> [0]PETSC ERROR: Trying to copy from a null pointer
> I executed with the following command:
> mpiexec -n 2 ./main -dm_vec_type cusp -vec_type cusp
> Both GPUs are attached to two different processes.
> This program works fine for vecmpi vectors, i.e., -dm_vec_type mpi and
> -vec_type mpi. Also, I don't get an error unless I try to *view* the
> vector. Can someone please point out what I'm doing wrong?
> Thanks for your time,
> Ashwin Srinath
> Dominic Meiser
> Tech-X Corporation
> 5621 Arapahoe Avenue
> Boulder, CO 80303
> USA
> Telephone: 303-996-2036
> Fax: 303-448-7756www.txcorp.com
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140718/053fe1ff/attachment.html>
