[petsc-users] Viewing DM Vector stored on Multiple GPUs
Dominic Meiser dmeiser at txcorp.com
Fri Jul 18 18:33:43 CDT 2014
Hi Ashwin,
I've been working on this issue the last couple of days and wanted to
give you an update. First off, thanks for the test case. This has helped
a lot in tracking down the issues. I've created a couple of unit tests
based on your test case.
There were several independent bugs that prevented the VecView to work
with -dm_vec_type cusp. I've fixed some of them in this branch:
https://bitbucket.org/dmeiser/petsc/branch/fix-cusp-dmda
Viewing a vector created from a DM should now be possible. For instance
the test case you provided should work with this branch.
There are still some issues remaining. DMGlobalToLocalBegin/End and
DMLocalToGlobalBegin/End are not working. I haven't been able to track
these down yet. I'll return to this next week.
Cheers,
Dominic
On 06/24/2014 08:15 PM, Ashwin Srinath wrote:
> Hello, petsc-users
> I'm having trouble /viewing/ an mpicusp vector. Here's the simplest
> case that reproduces the problem:
> int main(int argc, char** argv) {
>         PetscInitialize(&argc, &argv, NULL, NULL);
>         DM da;
>         Vec V;
>         DMDACreate2d(   PETSC_COMM_WORLD,
>                         DM_BOUNDARY_NONE, DM_BOUNDARY_NONE,
>                         DMDA_STENCIL_BOX,
>                         5, 5,
>                         PETSC_DECIDE, PETSC_DECIDE,
>                         1,
>                         1,
>                         NULL, NULL,
>                         &da);
>         DMCreateGlobalVector(da, &V);
>         VecSet(V, 1);
> VecView(V, PETSC_VIEWER_STDOUT_WORLD);
>         PetscFinalize();
>         return 0;
> I get the error:
> [1]PETSC ERROR: Null argument, when expecting valid pointer
> [0]PETSC ERROR: Trying to copy from a null pointer
> I executed with the following command:
> mpiexec -n 2 ./main -dm_vec_type cusp -vec_type cusp
> Both GPUs are attached to two different processes.
> This program works fine for vecmpi vectors, i.e., -dm_vec_type mpi and
> -vec_type mpi. Also, I don't get an error unless I try to /view/ the
> vector. Can someone please point out what I'm doing wrong?
> Thanks for your time,
> Ashwin Srinath
Dominic Meiser
Tech-X Corporation
5621 Arapahoe Avenue
Boulder, CO 80303
USA
Telephone: 303-996-2036
Fax: 303-448-7756
www.txcorp.com
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140718/4a61d14c/attachment.html>
