[petsc-users] PETSc 3.5.0 build with Hypre
Matthew Knepley
knepley at gmail.com
Fri Jul 11 09:38:31 CDT 2014
On Fri, Jul 11, 2014 at 4:28 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> On Fri, 11 Jul 2014, Wadud Miah wrote:
> > Hello,
> > I am trying to build PETSc 3.5.0 with Hypre 2.9.0b with the following
> configure options:
> > ./configure \
> > --with-hypre=1 \
> > --with-hypre-lib=/data/home/eew918/hypre-2.9.0b/lib \
> This should be: --with-hypre-lib="-L/data/home/eew918/hypre-2.9.0b/lib
> -lHYPRE"
> You are probably better off using --download-hypre instead
> > --with-hypre-include=/data/home/eew918/hypre-2.9.0b/include \
> > --LDFLAGS="-L/opt/intel/composer_xe_2013_sp1.2.144/mkl/lib/intel64
> -L/data/home/eew918/hypre-2.9.0b/lib" \
> > --with-blas-lib="mkl_intel_lp64 mkl_sequential mkl_core" \
> > --with-lapack-lib="mkl_intel_lp64 mkl_sequential mkl_core" \
> You can use
> --with-blas-lapack-lib=/opt/intel/composer_xe_2013_sp1.2.144/mkl [instead
> of the above 3 options
It should be -dir, not -lib.
Matt
> > --with-fortran-interfaces=1 \
> > --prefix=$HOME/petsc-3.5.0 \
> > --with-shared-libraries=1 \
> > --with-mpi=1 \
> > --with-mpi-include=/opt/openmpi/1.6.5/intel/13.1/include \
> > --with-mpi-lib=/opt/openmpi/1.6.5/intel/13.1/lib/libmpi.so
> You are better off using --with-mpi-dir=/opt/openmpi/1.6.5/intel/13.1
> [instead of the above 3 options
> Satish
> > But I keep getting the following error message during configure:
> > UNABLE to CONFIGURE with GIVEN OPTIONS (see configure.log
> for details):
> > --with-hypre-lib=['/data/home/eew918/hypre-2.9.0b/lib'] and
> > --with-hypre-include=['/data/home/eew918/hypre-2.9.0b/include'] did not
> work
> > I see the compilation command with the correct library path
> (-L/data/home/eew918/hypre-2.9.0b/lib) but no library name with the -l
> switch.
> > Regards,
> > Wadud Miah
> > Research Computing Services (HPC)
> > 020 7882 8393
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140711/efad9def/attachment.html>
