[petsc-users] PETSc 3.5.0 build with Hypre
Satish Balay
balay at mcs.anl.gov
Fri Jul 11 09:28:55 CDT 2014
On Fri, 11 Jul 2014, Wadud Miah wrote:
> Hello,
> I am trying to build PETSc 3.5.0 with Hypre 2.9.0b with the following configure options:
> ./configure \
> --with-hypre=1 \
> --with-hypre-lib=/data/home/eew918/hypre-2.9.0b/lib \
This should be: --with-hypre-lib="-L/data/home/eew918/hypre-2.9.0b/lib -lHYPRE"
You are probably better off using --download-hypre instead
> --with-hypre-include=/data/home/eew918/hypre-2.9.0b/include \
> --LDFLAGS="-L/opt/intel/composer_xe_2013_sp1.2.144/mkl/lib/intel64 -L/data/home/eew918/hypre-2.9.0b/lib" \
> --with-blas-lib="mkl_intel_lp64 mkl_sequential mkl_core" \
> --with-lapack-lib="mkl_intel_lp64 mkl_sequential mkl_core" \
You can use --with-blas-lapack-lib=/opt/intel/composer_xe_2013_sp1.2.144/mkl [instead of the above 3 options
> --with-fortran-interfaces=1 \
> --prefix=$HOME/petsc-3.5.0 \
> --with-shared-libraries=1 \
> --with-mpi=1 \
> --with-mpi-include=/opt/openmpi/1.6.5/intel/13.1/include \
> --with-mpi-lib=/opt/openmpi/1.6.5/intel/13.1/lib/libmpi.so
You are better off using --with-mpi-dir=/opt/openmpi/1.6.5/intel/13.1 [instead of the above 3 options
Satish
> But I keep getting the following error message during configure:
> UNABLE to CONFIGURE with GIVEN OPTIONS (see configure.log for details):
> --with-hypre-lib=['/data/home/eew918/hypre-2.9.0b/lib'] and
> --with-hypre-include=['/data/home/eew918/hypre-2.9.0b/include'] did not work
> I see the compilation command with the correct library path (-L/data/home/eew918/hypre-2.9.0b/lib) but no library name with the -l switch.
> Regards,
> Wadud Miah
> Research Computing Services (HPC)
> 020 7882 8393
