[petsc-users] How to set KSP Solver Options at Runtime?
Abhyankar, Shrirang G.
abhyshr at mcs.anl.gov
Wed Jul 9 23:04:30 CDT 2014
Shuangshuang,
You don't need
PCRegister("ourjacobi", PCCreate_Jacobi);
KSPGetPC(ksp, &pc);
PCSetType(pc, "ourjacobi");
in your code if you want to use PETSc's native Jacobi preconditioner. All
you have to do is set it at run-time -pc_type jacobi.
In PETSc, XXXSetFromOptions routine checks if a particular solver is
specified via a run-time option. If it is then that solver is set otherwise
it uses the default. KSPSetFromOptions sets the linear solver and the
preconditioner (runtime options -ksp_type and -pc_type),
SNESSetFromOptions
the nonlinear solver (runtime option -snes_type), and TSSetFromOptions the
time-stepping method (runtime option -ts_type).
There are other bunch of options for tuning preconditioners. Run your code
with -help option to see the list of options available.
Shri
From: "Jin, Shuangshuang" <Shuangshuang.Jin at pnnl.gov>
Date: Wed, 9 Jul 2014 23:37:19 +0000
To: "petsc-users at mcs.anl.gov" <petsc-users at mcs.anl.gov>
Subject: [petsc-users] How to set KSP Solver Options at Runtime?
>Hi, I¹m using the KSP solver as following to solve a linear system Ax=b,
>where A is a 16767x16767 square matrix, b is a 16767 length vector.
>EXTERN_C_BEGIN
>extern PetscErrorCode PCCreate_Jacobi(PC);
>EXTERN_C_END
>static PetscErrorCode solvingAxb(Mat A, Vec b, PetscInt nbus, Vec &x,
>const int me)
> PetscErrorCode ierr;
> KSP ksp; // linear solver context
> Vec u; // exact solution
> PetscInt its;
> PetscReal norm; // norm of solution error
> PetscLogDouble t1, t2;
> PetscViewer viewer;
> PC pc; // preconditioner context
> PetscInt Istart, Iend;
> ierr = VecDuplicate(b, &u); CHKERRQ(ierr);
> ierr = VecDuplicate(b, &x); CHKERRQ(ierr);
> ierr = KSPCreate(PETSC_COMM_WORLD, &ksp); CHKERRQ(ierr);
> ierr = KSPSetOperators(ksp, A, A, DIFFERENT_NONZERO_PATTERN);
>CHKERRQ(ierr);
> KSPGetPC(ksp, &pc);
> ierr = KSPSetFromOptions(ksp); CHKERRQ(ierr);
> ierr = KSPSolve(ksp, b, x); CHKERRQ(ierr);
> ierr = MatMult(A,x,u); CHKERRQ(ierr);
> ierr = VecAXPY(u, -1.0, b); CHKERRQ(ierr);
> ierr = VecNorm(u, NORM_2, &norm); CHKERRQ(ierr);
> ierr = KSPGetIterationNumber(ksp, &its); CHKERRQ(ierr);
> ierr = VecDestroy(&b); CHKERRQ(ierr);
> ierr = VecDestroy(&u); CHKERRQ(ierr);
> ierr = KSPDestroy(&ksp);CHKERRQ(ierr);
> PetscFunctionReturn(0);
>I would like to know how to set the solver options at runtime to make it
>run faster, such as ksp_type, pc_type, and etc? It takes very long time
>to solve the system if I use no options.
>Thanks,
>Shuangshuang
