[petsc-users] How to set KSP Solver Options at Runtime?
Wed Jul 9 18:53:21 CDT 2014
On Thu, Jul 10, 2014 at 1:37 AM, Jin, Shuangshuang <
Shuangshuang.Jin at pnnl.gov> wrote:
>  Hi, I’m using the KSP solver as following to solve a linear system Ax=b,
> where A is a 16767x16767 square matrix, b is a 16767 length vector.
> EXTERN_C_BEGIN
> extern PetscErrorCode PCCreate_Jacobi(PC);
> EXTERN_C_END
> static PetscErrorCode solvingAxb(Mat A, Vec b, PetscInt nbus, Vec &x,
> const int me)
>   PetscErrorCode ierr;
>   KSP ksp; // linear solver context
>   Vec u; // exact solution
>   PetscInt its;
>   PetscReal norm; // norm of solution error
>   PetscLogDouble t1, t2;
>   PetscViewer viewer;
>   PC pc; // preconditioner context
>   PetscInt Istart, Iend;
>   ierr = VecDuplicate(b, &u); CHKERRQ(ierr);
>   ierr = VecDuplicate(b, &x); CHKERRQ(ierr);
>   ierr = KSPCreate(PETSC_COMM_WORLD, &ksp); CHKERRQ(ierr);
>   ierr = KSPSetOperators(ksp, A, A, DIFFERENT_NONZERO_PATTERN);
> CHKERRQ(ierr);
>   PCRegister("ourjacobi", PCCreate_Jacobi);
>   KSPGetPC(ksp, &pc);
>   PCSetType(pc, "ourjacobi");
>   ierr = KSPSetFromOptions(ksp); CHKERRQ(ierr);
>   ierr = KSPSolve(ksp, b, x); CHKERRQ(ierr);
>   ierr = MatMult(A,x,u); CHKERRQ(ierr);
>   ierr = VecAXPY(u, -1.0, b); CHKERRQ(ierr);
>   ierr = VecNorm(u, NORM_2, &norm); CHKERRQ(ierr);
>   ierr = KSPGetIterationNumber(ksp, &its); CHKERRQ(ierr);
>   ierr = VecDestroy(&b); CHKERRQ(ierr);
>   ierr = VecDestroy(&u); CHKERRQ(ierr);
>   ierr = KSPDestroy(&ksp);CHKERRQ(ierr);
>   PetscFunctionReturn(0);
> I would like to know how to set the solver options at runtime to make it
> run faster, such as ksp_type, pc_type, and etc? It takes very long time to
> solve the system if I use no options.
The preconditioner always depends on the particular problem being solved.
You will have to tell us more about it.
   Matt
> Thanks,
> Shuangshuang
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140710/6c37fb89/attachment.html>
