[petsc-users] Preconditioners for a FEM model
jifeng zhao
jifengzhao2015 at u.northwestern.edu
Wed Jul 2 16:46:13 CDT 2014
Hello all,
I am working on solving a generalized eigenvalue problem with SLEPC and
PETSC.
*K* x = lamda *M* x
I attached the sparsity pattern of matrix *M* (*K* is the same). It is a
FEM model. It is so sparse is because of constraints.
I have tried two things:
1. Krylov-Schur and exact shift-and-invert (I will try MUMPS in future). It
works. But I am worrying that it is less parrallelable, when the problem
contains millions of degree of freedom.
2. JD with Jacobi preconditioner. It could work, but a lot of tuning needs
to be done in terms of RTOL, max_iteration_number. And sometimes I suffer
from a stagnated solution, and can't obtain accurate result.
Does anybody know that for my specific case of matrix sparsity, is there
any thing I can do to speed up my direct solver (Krylov-Schur)?
Is there any recommended preconditioners I could try on, for the case of
JD? There are a lot of preconditioners in HYPRE library.
Thank you in advance!
[image: Inline image 1]
Jifeng Zhao
PhD candidate at Northwestern University, US
Theoretical and Applied Mechanics Program
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140702/a458146c/attachment.html>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140702/a458146c/attachment.png>
