[petsc-users] Changing TSAdapt
Barry Smith
bsmith at mcs.anl.gov
Mon Dec 15 16:20:00 CST 2014
I have no idea how to revert something that is in maint, master, etc. Jed will need to fix this mess. I have no idea how to do it. I have no objection to someone taking out my fix and putting in yours, but it needs to go into maint in less than six months.
Barry
> On Dec 15, 2014, at 2:46 PM, Lisandro Dalcin <dalcinl at gmail.com> wrote:
> On 12 December 2014 at 01:44, Barry Smith <bsmith at mcs.anl.gov> wrote:
>> Miguel,
>> Thanks for reporting this, you have found a bug in our code. When we changed the adapt type we did not zero out the function pointers for the old basic adaptor hence they were improperly called when the object was finally destroyed at the end.
>> I've attached a patch. Once you apply this simply run
>> make gnumake
>> in the PETSc root directory, recompile your code and run it again and it should successfully end.
>> Barry
> Your patch also clears any user-specified adapt->ops->checkstage.
> Perhaps you should revert your commit and merge my PR instead?
> https://bitbucket.org/petsc/petsc/pull-request/228/fixes-for-ts-tsadapt-and-tsalpha/diff
> Lisandro Dalcin
> Research Scientist
> Computer, Electrical and Mathematical Sciences & Engineering (CEMSE)
> Numerical Porous Media Center (NumPor)
> King Abdullah University of Science and Technology (KAUST)
> http://numpor.kaust.edu.sa/
> 4700 King Abdullah University of Science and Technology
> al-Khawarizmi Bldg (Bldg 1), Office # 4332
> Thuwal 23955-6900, Kingdom of Saudi Arabia
> http://www.kaust.edu.sa
> Office Phone: +966 12 808-0459
