[petsc-users] Changing TSAdapt
Lisandro Dalcin
dalcinl at gmail.com
Mon Dec 15 14:46:17 CST 2014
On 12 December 2014 at 01:44, Barry Smith <bsmith at mcs.anl.gov> wrote:
> Miguel,
> Thanks for reporting this, you have found a bug in our code. When we changed the adapt type we did not zero out the function pointers for the old basic adaptor hence they were improperly called when the object was finally destroyed at the end.
> I've attached a patch. Once you apply this simply run
> make gnumake
> in the PETSc root directory, recompile your code and run it again and it should successfully end.
> Barry
Your patch also clears any user-specified adapt->ops->checkstage.
Perhaps you should revert your commit and merge my PR instead?
https://bitbucket.org/petsc/petsc/pull-request/228/fixes-for-ts-tsadapt-and-tsalpha/diff
Lisandro Dalcin
Research Scientist
Computer, Electrical and Mathematical Sciences & Engineering (CEMSE)
Numerical Porous Media Center (NumPor)
King Abdullah University of Science and Technology (KAUST)
http://numpor.kaust.edu.sa/
4700 King Abdullah University of Science and Technology
al-Khawarizmi Bldg (Bldg 1), Office # 4332
Thuwal 23955-6900, Kingdom of Saudi Arabia
http://www.kaust.edu.sa
Office Phone: +966 12 808-0459
