[petsc-users] Dirichlet boundary conditions for MATMPISBAIJ
Matthew Knepley
knepley at gmail.com
Thu Dec 4 15:16:24 CST 2014
On Thu, Dec 4, 2014 at 7:14 AM, Aurelia Cuba Ramos <
aurelia.cubaramos at epfl.ch> wrote:
> Hi all,
> I recently started using PETSc and I am working with the MATMPISBAIJ
> matrix format. I am trying to apply Dirichlet boundary conditions by
> calling MatZeroRowsColumns() but this function seems to be not available
> for symmetric block matrices in parallel. I saw on the FAQ website that
> another possible way is to use MatZeroRows() and -ksp_type preonly
> -pc_type redistribute. But when I try calling MatZeroRows() I get again
> a PetscErrorCode 56, so it doesn't seem to be supported neither. I am
> currently using PETSc 3.4. Is MatZeroRowsColumns() avaibale for
> MATMPISBAIJ in PETSc 3.5 and if not, what is the fastest way to apply
> Dirichlet BC's for this matrix format?
1) SBAIJ is just an optimization to save memory. I would get everything
running
with BAIJ, and then if you run out of memory switch to SBAIJ
2) We have only coded that up for the sequential version. I will add it to
our list.
Matt
> Many thanks,
> Aurelia
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20141204/cf8298ca/attachment.html>
