[petsc-users] valgrind
paul zhang
paulhuaizhang at gmail.com
Mon Dec 1 12:33:02 CST 2014
That is my new configuration. Is that OK?
export PETSC_DIR=`pwd`
export PETSC_ARCH=linux-gnu-intel
./configure --with-cc=gcc --with-cxx=g++ --with-fc=gfortran
--download-fblaslapack --download-mpich
--with-valgrind-dir=/share/cluster/RHEL6.2/x86_64/apps/valgrind/3.9.0
--with-mpi=1 --with-mpi-dir=/home/hzh225/LIB_CFD/openmpi-1.8.3/
Huaibao (Paul) Zhang
*Gas Surface Interactions Lab*
Department of Mechanical Engineering
University of Kentucky,
Lexington,
KY, 40506-0503
*Office*: 216 Ralph G. Anderson Building
*Web*:gsil.engineering.uky.edu
On Mon, Dec 1, 2014 at 1:28 PM, paul zhang <paulhuaizhang at gmail.com> wrote:
> I did use the PETSc makefiles. Should I include the valgrind path in my
> own make file again?
> [hzh225 at dlxlogin2-2 petsc-3.5.2]$ pwd
> /home/hzh225/LIB_CFD/nP/petsc-3.5.2
> [hzh225 at dlxlogin2-2 petsc-3.5.2]$ make getincludedirs
> -I/home/hzh225/LIB_CFD/nP/petsc-3.5.2/include
> -I/home/hzh225/LIB_CFD/nP/petsc-3.5.2/linux-gnu-intel/include
> -I/share/cluster/RHEL6.2/x86_64/apps/valgrind/3.9.0/include
> Lexington,
> KY, 40506-0503
> On Mon, Dec 1, 2014 at 11:55 AM, Matthew Knepley <knepley at gmail.com>
> wrote:
>> On Mon, Dec 1, 2014 at 10:43 AM, paul zhang <paulhuaizhang at gmail.com>
>> wrote:
>>> Matt,
>>> Thanks for your reply. I am able to compile PETSc. And I went through
>>> the default tests. Now when I go to my code, I got problems.
>> I am assuming that you put flags in your makefiles rather than using the
>> PETSc makefiles. You need all the includes you get from
>> make getincludedirs
>> Matt
>>> [hzh225 at dlxlogin2-1 petsc-3.5]$ make all
>>> [100%] Building CXX object CMakeFiles/kats.dir/main.cc.o
>>> /home/hzh225/LIB_CFD/nP/petsc-3.5.2/include/petscsys.h(1760):
>>> catastrophic error: cannot open source file "valgrind/valgrind.h"
>>> # include <valgrind/valgrind.h>
>>> compilation aborted for /home/hzh225/CMake/petsc/petsc-3.5/main.cc (code
>>> 4)
>>> make[2]: *** [CMakeFiles/kats.dir/main.cc.o] Error 4
>>> make[1]: *** [CMakeFiles/kats.dir/all] Error 2
>>> make: *** [all] Error 2
>>> Lexington,
>>> KY, 40506-0503
>>> On Mon, Dec 1, 2014 at 11:28 AM, Matthew Knepley <knepley at gmail.com>
>>> wrote:
>>>> On Mon, Dec 1, 2014 at 10:21 AM, paul zhang <paulhuaizhang at gmail.com>
>>>> wrote:
>>>>> Hi All,
>>>>> How to enable the valgrind flag? I installed that by myself locally.
>>>>> It appears you do not have valgrind installed on your system.
>>>>> We HIGHLY recommend you install it from
>>>>> www.valgrind.org
>>>>> Or install
>>>>> valgrind-devel or equivalent using your package manager.
>>>>> Then rerun ./configure
>>>> We could not find the valgrind header (valgrind.h). You can use
>>>> --with-valgrind-dir=<path>
>>>> so that it can find the path/include/valgrind/valgrind.h
>>>> Thanks,
>>>> Matt
>>>>> Thanks,
>>>>> Paul
>>>> What most experimenters take for granted before they begin their
>>>> experiments is infinitely more interesting than any results to which their
>>>> experiments lead.
>>>> -- Norbert Wiener
>> experiments lead.
>> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20141201/7303e460/attachment-0001.html>
