[petsc-users] valgrind
Mon Dec 1 10:55:29 CST 2014
On Mon, Dec 1, 2014 at 10:43 AM, paul zhang <paulhuaizhang at gmail.com> wrote:
> Matt,
> Thanks for your reply. I am able to compile PETSc. And I went through the
> default tests. Now when I go to my code, I got problems.
I am assuming that you put flags in your makefiles rather than using the
PETSc makefiles. You need all the includes you get from
   make getincludedirs
    Matt
> [hzh225 at dlxlogin2-1 petsc-3.5]$ make all
> [100%] Building CXX object CMakeFiles/kats.dir/main.cc.o
> /home/hzh225/LIB_CFD/nP/petsc-3.5.2/include/petscsys.h(1760): catastrophic
> error: cannot open source file "valgrind/valgrind.h"
>   #  include <valgrind/valgrind.h>
> compilation aborted for /home/hzh225/CMake/petsc/petsc-3.5/main.cc (code 4)
> make[2]: *** [CMakeFiles/kats.dir/main.cc.o] Error 4
> make[1]: *** [CMakeFiles/kats.dir/all] Error 2
> make: *** [all] Error 2
> Huaibao (Paul) Zhang
> *Gas Surface Interactions Lab*
> Department of Mechanical Engineering
> University of Kentucky,
> Lexington,
> KY, 40506-0503
> *Office*: 216 Ralph G. Anderson Building
> *Web*:gsil.engineering.uky.edu
> On Mon, Dec 1, 2014 at 11:28 AM, Matthew Knepley <knepley at gmail.com>
> wrote:
>> On Mon, Dec 1, 2014 at 10:21 AM, paul zhang <paulhuaizhang at gmail.com>
>> wrote:
>>> Hi All,
>>> How to enable the valgrind flag? I installed that by myself locally.
>>>       It appears you do not have valgrind installed on your system.
>>>                    We HIGHLY recommend you install it from
>>> www.valgrind.org
>>>                                                   Or install valgrind-devel
>>> or equivalent using your package manager.
>>>                                                            Then rerun
>>> ./configure
>> We could not find the valgrind header (valgrind.h). You can use
>>   --with-valgrind-dir=<path>
>> so that it can find the path/include/valgrind/valgrind.h
>>   Thanks,
>>     Matt
>>> Thanks,
>>> Paul
>> experiments lead.
>> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20141201/9f8c0297/attachment-0001.html>
