[petsc-users] MATSOLVERSUPERLU_DIST not giving the correct	solution
    Matthew Knepley
    knepley at gmail.com
    Wed Apr 30 06:46:20 CDT 2014
On Wed, Apr 30, 2014 at 6:19 AM, Justin Dong <jsd1 at rice.edu> wrote:
> Thanks. If I turn on the Krylov solver, the issue still seems to persist
> though.
> mpiexec -n 4 -ksp_type gmres -ksp_rtol 1.0e-13 -pc_type lu
> -pc_factor_mat_solver_package superlu_dist
> I'm testing on a very small system now (24 ndofs), but if I go larger
> (around 20000 ndofs) then it gets worse.
> For the small system, I exported the matrices to matlab to make sure they
> were being assembled correct in parallel, and I'm certain that that they
> are.
For convergence questions, always run using -ksp_monitor -ksp_view so that
we can see exactly what you run.
     Matt
> On Wed, Apr 30, 2014 at 5:32 AM, Matthew Knepley <knepley at gmail.com>wrote:
>> On Wed, Apr 30, 2014 at 3:02 AM, Justin Dong <jsd1 at rice.edu> wrote:
>>> I actually was able to solve my own problem...for some reason, I need to
>>> do
>>> PCSetType(pc, PCLU);
>>> PCFactorSetMatSolverPackage(pc, MATSOLVERSUPERLU_DIST);
>>> KSPSetTolerances(ksp, 1.e-15, PETSC_DEFAULT, PETSC_DEFAULT,
>>> PETSC_DEFAULT);
>> 1) Before you do SetType(PCLU) the preconditioner has no type, so
>> FactorSetMatSolverPackage() has no effect
>> 2) There is a larger issue here. Never ever ever ever code in this way.
>> Hardcoding a solver is crazy. The solver you
>>      use should depend on the equation, discretization, flow regime, and
>> architecture. Recompiling for all those is
>>      out of the question. You should just use
>>     KSPCreate()
>>     KSPSetOperators()
>>     KSPSetFromOptions()
>>     KSPSolve()
>> and then
>>    -pc_type lu -pc_factor_mat_solver_package superlu_dist
>>> instead of the ordering I initially had, though I'm not really clear on
>>> what the issue was. However, there seems to be some loss of accuracy as I
>>> increase the number of processes. Is this expected, or can I force a lower
>>> tolerance somehow? I am able to compare the solutions to a reference
>>> solution, and the error increases as I increase the processes. This is the
>>> solution in sequential:
>> Yes, this is unavoidable. However, just turn on the Krylov solver
>>   -ksp_type gmres -ksp_rtol 1.0e-10
>> and you can get whatever residual tolerance you want. To get a specific
>> error, you would need
>> a posteriori error estimation, which you could include in a custom
>> convergence criterion.
>>   Thanks,
>>      Matt
>>> superlu_1process = [
>>> -6.8035811950925553e-06
>>> 1.6324030474375778e-04
>>> 5.4145340579614926e-02
>>> 1.6640521936281516e-04
>>> -1.7669374392923965e-04
>>> -2.8099208957838207e-04
>>> 5.3958133511222223e-02
>>> -5.4077899123806263e-02
>>> -5.3972905090366369e-02
>>> -1.9485020474821160e-04
>>> 5.4239813043824400e-02
>>> 4.4883984259948430e-04];
>>> superlu_2process = [
>>> -6.8035811950509821e-06
>>> 1.6324030474371623e-04
>>> 5.4145340579605655e-02
>>> 1.6640521936281687e-04
>>> -1.7669374392923807e-04
>>> -2.8099208957839834e-04
>>> 5.3958133511212911e-02
>>> -5.4077899123796964e-02
>>> -5.3972905090357078e-02
>>> -1.9485020474824480e-04
>>> 5.4239813043815172e-02
>>> 4.4883984259953320e-04];
>>> superlu_4process= [
>>> -6.8035811952565206e-06
>>> 1.6324030474386164e-04
>>> 5.4145340579691455e-02
>>> 1.6640521936278326e-04
>>> -1.7669374392921441e-04
>>> -2.8099208957829171e-04
>>> 5.3958133511299078e-02
>>> -5.4077899123883062e-02
>>> -5.3972905090443085e-02
>>> -1.9485020474806352e-04
>>> 5.4239813043900860e-02
>>> 4.4883984259921287e-04];
>>> This is some finite element solution and I can compute the error of the
>>> solution against an exact solution in the functional L2 norm:
>>> error with 1 process:    1.71340e-02 (accepted value)
>>> error with 2 processes: 2.65018e-02
>>> error with 3 processes: 3.00164e-02
>>> error with 4 processes: 3.14544e-02
>>> Is there a way to remedy this?
>>> On Wed, Apr 30, 2014 at 2:37 AM, Justin Dong <jsd1 at rice.edu> wrote:
>>>> Hi,
>>>> I'm trying to solve a linear system in parallel using SuperLU but for
>>>> some reason, it's not giving me the correct solution. I'm testing on a
>>>> small example so I can compare the sequential and parallel cases manually.
>>>> I'm absolutely sure that my routine for generating the matrix and
>>>> right-hand side in parallel is working correctly.
>>>> Running with 1 process and PCLU gives the correct solution. Running
>>>> with 2 processes and using SUPERLU_DIST does not give the correct solution
>>>> (I tried with 1 process too but according to the superlu documentation, I
>>>> would need SUPERLU for sequential?). This is the code for solving the
>>>> system:
>>>>         /* solve the system */
>>>> KSPCreate(PETSC_COMM_WORLD, &ksp);
>>>> KSPSetOperators(ksp, Aglobal, Aglobal, DIFFERENT_NONZERO_PATTERN);
>>>>  KSPSetType(ksp,KSPPREONLY);
>>>> KSPGetPC(ksp, &pc);
>>>> KSPSetTolerances(ksp, 1.e-13, PETSC_DEFAULT, PETSC_DEFAULT,
>>>> PETSC_DEFAULT);
>>>> KSPSolve(ksp, bglobal, bglobal);
>>>> Sincerely,
>>>> Justin
>> experiments lead.
>> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140430/9fa9e1fa/attachment-0001.html>
