[petsc-users] Problem with DMDAVecGetArrayF90 and DMDAVecRestoreArrayF90
Jed Brown jed at jedbrown.org
Mon Apr 14 21:42:24 CDT 2014
TAY wee-beng <zonexo at gmail.com> writes:
> Hi Barry,
> As I mentioned earlier, the code works fine in PETSc debug mode but
> fails in non-debug mode.
> My code works in this way:
> */DM  da_u,da_v,da_w/**/
> /**/Vec
This formatting is NOT easy to read.  Please send text.
http://lists.mcs.anl.gov/pipermail/petsc-users/2014-April/021239.html
> /**/To access the arrays, I did the following:/**/
> /**/call DMDAVecGetArrayF90(da_u,u_local,u_array,ierr);    call
> DMDAVecGetArrayF90(da_v,v_local,v_array,ierr);    call
> DMDAVecGetArrayF90(da_w,w_local,w_array,ierr)/**/
> /**/call I_IIB_uv_initial_1st_dm0(...,u_array,v_array,w_array)/**/
> /**/call DMDAVecRestoreArrayF90(da_w,w_local,w_array,ierr)/**/
> /**/call DMDAVecRestoreArrayF90(da_v,v_local,v_array,ierr)/**/-> hangs
> at this point/**/or/**/
Which processes hang here?  Where are the other processes?  Get stack
traces for each process.  You can build in "optimized" mode with
debugging symbols.
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140414/460572cc/attachment.pgp>
