[petsc-users] Problem with DMDAVecGetArrayF90 and DMDAVecRestoreArrayF90
TAY wee-beng zonexo at gmail.com
Mon Apr 14 21:32:12 CDT 2014
Hi Barry,
As I mentioned earlier, the code works fine in PETSc debug mode but
fails in non-debug mode.
My code works in this way:
*/DM  da_u,da_v,da_w/**/
/**/Vec
u_local,u_global,v_local,v_global,w_local,w_global,p_local,p_global/**/
/**/call
DMDACreate3d(MPI_COMM_WORLD,DMDA_BOUNDARY_NONE,DMDA_BOUNDARY_NONE,DMDA_BOUNDARY_NONE,DMDA_STENCIL_STAR,size_x,size_y,&/**/
/**/size_z,1,1,num_procs,1,stencil_width,lx,ly,lz,da_u,ierr)/**/
/**/call
/**/size_z,1,1,num_procs,1,stencil_width,lx,ly,lz,da_v,ierr)/**/
/**/    call
/**/size_z,1,1,num_procs,1,stencil_width,lx,ly,lz,da_w,ierr)/**/
/**/call DMCreateGlobalVector(da_u,u_global,ierr)/**/
/**/    call DMCreateLocalVector(da_u,u_local,ierr)/**/
/**/    call DMCreateGlobalVector(da_v,v_global,ierr)/**/
/**/    call DMCreateLocalVector(da_v,v_local,ierr)/**/
/**/    call DMCreateGlobalVector(da_w,w_global,ierr)/**/
/**/    call DMCreateLocalVector(da_w,w_local,ierr)/**/
/**/To access the arrays, I did the following:/**/
/**/call DMDAVecGetArrayF90(da_u,u_local,u_array,ierr);    call
DMDAVecGetArrayF90(da_v,v_local,v_array,ierr);    call
DMDAVecGetArrayF90(da_w,w_local,w_array,ierr)/**/
/**/call I_IIB_uv_initial_1st_dm0(...,u_array,v_array,w_array)/**/
/**/call DMDAVecRestoreArrayF90(da_w,w_local,w_array,ierr)/**/
/**/call DMDAVecRestoreArrayF90(da_v,v_local,v_array,ierr)/**/-> hangs
at this point/**/or/**/
/**/call DMDAVecRestoreArrayF90(da_u,u_local,u_array,ierr)    -> hangs
at this point/**/
/**/subroutine I_IIB_uv_initial_1st_dm0(...,I_cell_w,u,v,w)/**/
/**/integer :: i,j,k,ijk/**/
/**/real(8), intent(inout) :: u(:,:,:),v(:,:,:),w(:,:,:)/**/
/**/    u(i-1,j-1,k-1)=0./**/
/**/    v(i-1,j-1,k-1)=0./**/
/**/   w(i-1,j-1,k-1)=0./**/
/**/end subroutine I_IIB_uv_initial_1st_dm0/*
Thank you
Yours sincerely,
TAY wee-beng
On 15/4/2014 2:26 AM, Barry Smith wrote:
>    Please send the code that creates da_w and the declarations of w_array
>    Barry
> On Apr 14, 2014, at 9:40 AM, TAY wee-beng <zonexo at gmail.com> wrote:
>> Hi Barry,
>> I'm not too sure how to do it. I'm running mpi. So I run:
>>   mpirun -n 4 ./a.out -start_in_debugger
>> I got the msg below. Before the gdb windows appear (thru x11), the program aborts.
>> Also I tried running in another cluster and it worked. Also tried in the current cluster in debug mode and it worked too.
>> An MPI process has executed an operation involving a call to the
>> "fork()" system call to create a child process.  Open MPI is currently
>> operating in a condition that could result in memory corruption or
>> other system errors; your MPI job may hang, crash, or produce silent
>> data corruption.  The use of fork() (or system() or other calls that
>> create child processes) is strongly discouraged.
>> The process that invoked fork was:
>>    Local host:          n12-76 (PID 20235)
>>    MPI_COMM_WORLD rank: 2
>> If you are *absolutely sure* that your application will successfully
>> and correctly survive a call to fork(), you may disable this warning
>> by setting the mpi_warn_on_fork MCA parameter to 0.
>> [2]PETSC ERROR: PETSC: Attaching gdb to ./a.out of pid 20235 on display localhost:50.0 on machine n12-76
>> [0]PETSC ERROR: PETSC: Attaching gdb to ./a.out of pid 20233 on display localhost:50.0 on machine n12-76
>> [1]PETSC ERROR: PETSC: Attaching gdb to ./a.out of pid 20234 on display localhost:50.0 on machine n12-76
>> [3]PETSC ERROR: PETSC: Attaching gdb to ./a.out of pid 20236 on display localhost:50.0 on machine n12-76
>> [n12-76:20232] 3 more processes have sent help message help-mpi-runtime.txt / mpi_init:warn-fork
>> [n12-76:20232] Set MCA parameter "orte_base_help_aggregate" to 0 to see all help / error messages
>>   1
>> [1]PETSC ERROR: ------------------------------------------------------------------------
>> [1]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation, probably memory access out of range
>> [1]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
>> [1]PETSC ERROR: or see http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind[1]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac OS X to find memory corruption errors
>> [1]PETSC ERROR: configure using --with-debugging=yes, recompile, link, and run
>> [1]PETSC ERROR: to get more information on the crash.
>> [1]PETSC ERROR: User provided function() line 0 in unknown directory unknown file (null)
>> [3]PETSC ERROR: ------------------------------------------------------------------------
>> [3]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation, probably memory access out of range
>> [3]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
>> [3]PETSC ERROR: or see http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind[3]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac OS X to find memory corruption errors
>> [3]PETSC ERROR: configure using --with-debugging=yes, recompile, link, and run
>> [3]PETSC ERROR: to get more information on the crash.
>> [3]PETSC ERROR: User provided function() line 0 in unknown directory unknown file (null)
>> Thank you.
>> Yours sincerely,
>> TAY wee-beng
>> On 14/4/2014 9:05 PM, Barry Smith wrote:
>>>    Because IO doesn’t always get flushed immediately it may not be hanging at this point.  It is better to use the option -start_in_debugger then type cont in each debugger window and then when you think it is “hanging” do a control C in each debugger window and type where to see where each process is you can also look around in the debugger at variables to see why it is “hanging” at that point.
>>>     Barry
>>>    This routines don’t have any parallel communication in them so are unlikely to hang.
>>> On Apr 14, 2014, at 6:52 AM, TAY wee-beng
>>>   wrote:
>>>> Hi,
>>>> My code hangs and I added in mpi_barrier and print to catch the bug. I found that it hangs after printing "7". Is it because I'm doing something wrong? I need to access the u,v,w array so I use DMDAVecGetArrayF90. After access, I use DMDAVecRestoreArrayF90.
>>>>          call MPI_Barrier(MPI_COMM_WORLD,ierr);  if (myid==0) print *,"3"
>>>>          call DMDAVecGetArrayF90(da_v,v_local,v_array,ierr)
>>>>          call MPI_Barrier(MPI_COMM_WORLD,ierr);  if (myid==0) print *,"4"
>>>>          call DMDAVecGetArrayF90(da_w,w_local,w_array,ierr)
>>>>          call MPI_Barrier(MPI_COMM_WORLD,ierr);  if (myid==0) print *,"5"
>>>>          call I_IIB_uv_initial_1st_dm(I_cell_no_u1,I_cell_no_v1,I_cell_no_w1,I_cell_u1,I_cell_v1,I_cell_w1,u_array,v_array,w_array)
>>>>          call MPI_Barrier(MPI_COMM_WORLD,ierr);  if (myid==0) print *,"6"
>>>>          call DMDAVecRestoreArrayF90(da_w,w_local,w_array,ierr)  !must be in reverse order
>>>>          call MPI_Barrier(MPI_COMM_WORLD,ierr);  if (myid==0) print *,"7"
>>>>          call MPI_Barrier(MPI_COMM_WORLD,ierr);  if (myid==0) print *,"8"
>>>> Thank you.
>>>> Yours sincerely,
>>>> TAY wee-beng
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140415/89bd1c3a/attachment-0001.html>
