[petsc-users] Difference between ex5f, ex5f90 and ex5f90t
Wed Apr 2 08:26:28 CDT 2014
On Wed, Apr 2, 2014 at 5:18 AM, TAY wee-beng <zonexo at gmail.com> wrote:
>  Hi,
> May I know what's the difference between ex5f, ex5f90 and ex5f90t?
This describes the various options:
http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Sys/UsingFortran.html
    Matt
> I wrote my CFD code in F90, and I would like to create a Poisson solver
> subroutine based on the ex5 example. The solver will be placed inside a
> module.
> So which is the preferred format to use?
> Btw, my code is something like this:
> *module PETSc_solvers*
> *use set_matrix*
> *use ibm*
> *implicit none*
> *contains*
> *subroutine semi_momentum_simple_xyz(du,dv,dw)*
> *!discretise momentum eqn using semi-implicit mtd*
> *!simple except east,west*
> *#include "finclude/petsc.h90"*
> * PetscViewer    viewer PetscScalar, pointer :: xx_v(:)*
> *integer :: i,j,k,ijk,ierr,JJ,kk,*
> Thank you
> Yours sincerely,
> TAY wee-beng
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140402/b08bc94c/attachment.html>
