[petsc-users] Difference between ex5f, ex5f90 and ex5f90t
TAY wee-beng zonexo at gmail.com
Wed Apr 2 05:18:55 CDT 2014
May I know what's the difference between ex5f, ex5f90 and ex5f90t?
I wrote my CFD code in F90, and I would like to create a Poisson solver
subroutine based on the ex5 example. The solver will be placed inside a
module.
So which is the preferred format to use?
Btw, my code is something like this:
/*module PETSc_solvers*//*
*//*use set_matrix*//*
*//*use ibm*//*
*//*implicit none*//*
*//*contains*//*
*//*subroutine semi_momentum_simple_xyz(du,dv,dw)*//*
*//*!discretise momentum eqn using semi-implicit mtd*//*
*//*!simple except east,west*//*
*//*#include "finclude/petsc.h90"*//*
PetscViewer    viewer
PetscScalar, pointer :: xx_v(:)*//*
*//*integer :: i,j,k,ijk,ierr,JJ,kk,*/
Thank you
Yours sincerely,
TAY wee-beng
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140402/45f18b8e/attachment.html>
