[petsc-users] Tensor product as matrix free method
Mathis Friesdorf mathisfriesdorf at gmail.com
Tue Apr 1 10:00:01 CDT 2014
Alright, so your point is that while this construction is in principal
possible, it will not be efficient. Thanks for clearing this up!
On Tue, Apr 1, 2014 at 4:57 PM, Jed Brown <jed at jedbrown.org> wrote:
> Mathis Friesdorf <mathisfriesdorf at gmail.com> writes:
> > Thanks Jed, this is great. I was trying to implement what was proposed in
> http://lists.mcs.anl.gov/pipermail/petsc-users/2011-September/009991.html,
> > by you as I just realised. For this the matrices would be of varying
> size,
> > so for three local systems, I would need:
> > S \otimes Id \otimes Id ; Id \otimes S \otimes Id ; Id \otimes Id
> \otimes S.
> > Realistic systems are of the order of at least 20 local systems, which
> > would mean that I need the matrices of the above structure for all 20
> > possible positions.
> This is something for which you should use CTF or TCE.  When S moves out
> of the last position in the tensor product, the operation becomes less
> local and various forms of transposition is needed.  This is not
> something worth recreating in PETSc unless there is a critical
> deficiency in the available libraries.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140401/6d462543/attachment.html>
