[petsc-users] Could not find make when building PETSc in Windows 7
Wed Oct 30 20:52:59 CDT 2013
Thanks for the confirmation. We'll try to add in a check for this in configure.
Satish
On Wed, 30 Oct 2013, Qin Lu wrote:
> Satish,
> I just got chance to try your two suggestions and the errors are gone!
> Many thanks,
> Qin
> On Wednesday, October 30, 2013 6:59 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> On Mon, 28 Oct 2013, Satish Balay wrote:
> >   "/usr/bin/ar: petscvecmod.o: No such file or directory
> > Mostlikely this is related to using 'winzip' or '7zip' to untar petsc
> > sources. Try using 'tar' from cygwin.
> > Or you can ignore this issue if not using f90 modules from your code.
> Could you confirm if you used winzip or equivalent to extract petsc sources?
> And does this error go away if you use 'tar -xzf petsc.tar.gz' to extract sources?
> thanks,
> Satish
