[petsc-users] Could not find make when building PETSc in Windows 7
Qin Lu
lu_qin_2000 at yahoo.com
Wed Oct 30 20:45:33 CDT 2013
Satish,
I just got chance to try your two suggestions and the errors are gone!
Many thanks,
Qin
On Wednesday, October 30, 2013 6:59 PM, Satish Balay <balay at mcs.anl.gov> wrote:
On Mon, 28 Oct 2013, Satish Balay wrote:
> "/usr/bin/ar: petscvecmod.o: No such file or directory
> Mostlikely this is related to using 'winzip' or '7zip' to untar petsc
> sources. Try using 'tar' from cygwin.
> Or you can ignore this issue if not using f90 modules from your code.
Could you confirm if you used winzip or equivalent to extract petsc sources?
And does this error go away if you use 'tar -xzf petsc.tar.gz' to extract sources?
thanks,
Satish
