[petsc-users] Could not find make when building PETSc in Windows 7
Qin Lu
lu_qin_2000 at yahoo.com
Mon Oct 28 09:36:31 CDT 2013
The configuration seemed to work, then I ran "make all" but got errors such as "grep: Cannot open file '/dev/fs/C/cygdrive/c/cygwin_cache/petsc-3.4.3/include/petscversion.h': No such file or directory". See the attached error.log and make.log for details.
I confirmed that c:\cygwin_cache\petsc-3.4.3\include\petscversion.h is there. '\The ''/dev/fs/C' part in the directory seems suspicious. Did I missed anything in the setup?
Thanks for any hints,
Qin
On Thursday, October 24, 2013 2:05 PM, Satish Balay <balay at mcs.anl.gov> wrote:
pushed ee76e990026b11c1f9c153f288b72cc9b8ebb100 and merged to next.
It will go into 'maint' later..
Satish
On Thu, 24 Oct 2013, Satish Balay wrote:
> Perhaps we should add back the windows-python check?
> [since we haven't yet added the windows python support]
> Satish
> On Thu, 24 Oct 2013, Qin Lu wrote:
> > Chetan
> > Great, that was the problem! I set python point to a copy that was not cygwin's. Now I set it to cygwin's python and it this error is gone! I am waiting to see if the whole building will finish without problems.
> > Thanks a lot for all you guys' helps.
> > Qin
> > On Thursday, October 24, 2013 11:28 AM, Chetan Jhurani <chetan.jhurani at gmail.com> wrote:
> > I vaguely recall seeing the "could not locate make" error
> > when a non-cygwin python is picked up first in path.
> > So ensure that "which python" points to cygwin python.
> > Another issue is that the --with-make argument, if it is
> > needed, should be /cygdrive/C/cygwin64/bin (or with some
> > other drive letter in between where cygwin is installed).
> > Chetan
> > > -----Original Message-----
> > > From: petsc-users-bounces at mcs.anl.gov [mailto:petsc-users-bounces at mcs.anl.gov] On Behalf Of Qin Lu
> > > Sent: Thursday, October 24, 2013 8:43 AM
> > > To: Jed Brown; petsc-users at mcs.anl.gov
> > > Subject: Re: [petsc-users] Could not find make when building PETSc in Windows 7
> > > Jed,
> > > As I mentioned, I did add C:\cygwin64\bin (where make.exe is) to Path, and also tried to run
> > > ./configure --with-cc='win32fe icl' --with-fc='win32fe ifort' --with-cxx='win32fe icl' --with-
> > > make=/cygdrive/cygwin64/bin. It did not work, I just tried what you suggested: adding --download-make
> > > in confugure, it gave the same error.
> > > Thanks,
> > > Qin
> > > On Thursday, October 24, 2013 10:36 AM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> > > Qin Lu <lu_qin_2000 at yahoo.com> writes:
> > > > Hello,
> > > > I am trying to build PETSc in Windows 7 with following steps:
> > > > 1. Installed cygwin 64-bit with python, make and other default packages under C:\cygwin64
> > > > 2. Added C:\cygwin64\bin to Windows environmental variable Path.
> > > > 3. Downloaded and unzipped PETSc 3.4.2.
> > > > 4. Run mintty.exe to open a cygwin terminal.
> > > > 5. In the cygwin terminal, under PETSc directory, run: ./configure --with-cc='win32fe icl' --with-
> > > > However, it gave an error "Could not locate the make utility on your system, make sure it is in your
> > > path or use --with-make=/fullpathnameofmake and run ./configure again". I suppose it should use
> > > C:\cygwin64\bin\make.exe, which is already in path, but I still added --with-
> > > make=/cvgdrive/cygwin64/bin in configure's option and run configure again, yet it gave the same error.
> > > You need to pass the full path to the make executable (or add it to your
> > > path), or you can use --download-make.
> > > > What should I do to let configure know the path of make?
> > > > Many thanks for your help,
> > > > Regard,
> > > > Qin
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20131028/548cd2ff/attachment-0001.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20131028/548cd2ff/attachment-0002.obj>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20131028/548cd2ff/attachment-0003.obj>
