[petsc-users] PetscOptionsView() line 692
Matthew Knepley
knepley at gmail.com
Fri Oct 25 19:46:46 CDT 2013
On Fri, Oct 25, 2013 at 7:41 PM, Mark Adams <mfadams at lbl.gov> wrote:
> I have seen this several times over the past year or so. It is in an
> application. It is at the end of the run and not using -options_left fixes
> it. I'm not set up on this machine and I don't have permissions to run a
> test. I have to think that there is some funny interaction with the way we
> build or something. So our user is happy now. Lets just hope this problem
> goes back to where it came from.
This is real. I had it. Looking...
Matt
> On Fri, Oct 25, 2013 at 8:31 PM, Satish Balay <balay at mcs.anl.gov> wrote:
>> I can't reproduce this.
>> Is this reproduceable with the PETSc examples with your build?
>> Satish
>> On Fri, 25 Oct 2013, Mark Adams wrote:
>> > Has this been fixed in latter releases? Would removing -options_left
>> fix
>> > this?
>> > [0]PETSC ERROR: No support for this operation for this object type!
>> > [0]PETSC ERROR: Only supports ASCII viewer!
>> > [0]PETSC ERROR:
>> > [0]PETSC ERROR: Petsc Release Version 3.4.0, May, 13, 2013
>> > [0]PETSC ERROR: See docs/changes/index.html for recent updates.
>> > [0]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
>> > [0]PETSC ERROR: See docs/index.html for manual pages.
>> > [0]PETSC ERROR:
>> > [0]PETSC ERROR: ./driver2d.Linux.64.mpiCC.mpif90.DEBUG.MPI.PETSC.ex on a
>> > arch-linux-gnu-anag-parallel-opt named loren by dmartin Fri Oct 25
>> 15:20:25
>> > 2013
>> > [0]PETSC ERROR: Libraries linked from
>> > /usr/local/anag/pkg/petsc-3.4.0/arch-linux-gnu-anag-parallel-opt/lib
>> > [0]PETSC ERROR: Configure run at Wed May 22 18:57:17 2013
>> > [0]PETSC ERROR: Configure options --with-x=0 --download-hypre=1
>> > --download-parmetis=1 --download-metis=1 --with-debugging=0 --with-mpi=1
>> > PETSC_ARCH=arch-linux-gnu-anag-parallel-opt
>> > [0]PETSC ERROR:
>> > [0]PETSC ERROR: PetscOptionsView() line 692 in
>> > /usr/local/anag/pkg/petsc-3.4.0/src/sys/objects/options.c
>> > [0]PETSC ERROR: PetscFinalize() line 1048 in
>> > /usr/local/anag/pkg/petsc-3.4.0/src/sys/objects/pinit.c
>> > [0]PETSC ERROR: main() line 1141 in "unknowndirectory/"driver.cpp
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20131025/efa5f86d/attachment.html>
