[petsc-users] PetscOptionsView() line 692
Mark Adams
mfadams at lbl.gov
Fri Oct 25 19:41:52 CDT 2013
I have seen this several times over the past year or so. It is in an
application. It is at the end of the run and not using -options_left fixes
it. I'm not set up on this machine and I don't have permissions to run a
test. I have to think that there is some funny interaction with the way we
build or something. So our user is happy now. Lets just hope this problem
goes back to where it came from.
On Fri, Oct 25, 2013 at 8:31 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> I can't reproduce this.
> Is this reproduceable with the PETSc examples with your build?
> Satish
> On Fri, 25 Oct 2013, Mark Adams wrote:
> > Has this been fixed in latter releases? Would removing -options_left fix
> > this?
> > [0]PETSC ERROR: No support for this operation for this object type!
> > [0]PETSC ERROR: Only supports ASCII viewer!
> > [0]PETSC ERROR:
> > [0]PETSC ERROR: Petsc Release Version 3.4.0, May, 13, 2013
> > [0]PETSC ERROR: See docs/changes/index.html for recent updates.
> > [0]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
> > [0]PETSC ERROR: See docs/index.html for manual pages.
> > [0]PETSC ERROR:
> > [0]PETSC ERROR: ./driver2d.Linux.64.mpiCC.mpif90.DEBUG.MPI.PETSC.ex on a
> > arch-linux-gnu-anag-parallel-opt named loren by dmartin Fri Oct 25
> 15:20:25
> > 2013
> > [0]PETSC ERROR: Libraries linked from
> > /usr/local/anag/pkg/petsc-3.4.0/arch-linux-gnu-anag-parallel-opt/lib
> > [0]PETSC ERROR: Configure run at Wed May 22 18:57:17 2013
> > [0]PETSC ERROR: Configure options --with-x=0 --download-hypre=1
> > --download-parmetis=1 --download-metis=1 --with-debugging=0 --with-mpi=1
> > PETSC_ARCH=arch-linux-gnu-anag-parallel-opt
> > [0]PETSC ERROR:
> > [0]PETSC ERROR: PetscOptionsView() line 692 in
> > /usr/local/anag/pkg/petsc-3.4.0/src/sys/objects/options.c
> > [0]PETSC ERROR: PetscFinalize() line 1048 in
> > /usr/local/anag/pkg/petsc-3.4.0/src/sys/objects/pinit.c
> > [0]PETSC ERROR: main() line 1141 in "unknowndirectory/"driver.cpp
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20131025/e2f3e0b0/attachment-0001.html>
