[petsc-users] Could not find make when building PETSc in Windows 7
Qin Lu
lu_qin_2000 at yahoo.com
Thu Oct 24 11:26:44 CDT 2013
Satish,
I ran the configure in mintty's terminal.
"echo $PATH" showed PATH included /usr/bin. "which make" showed "/usr/bin/make". I tried petsc 3.4.3 with either --with-make or --download-make option and configure got the same error.
The configure.log is attached.
Is there simple anyway to test if cygwin has been set up properly?
Qin
On Thursday, October 24, 2013 10:47 AM, Satish Balay <balay at mcs.anl.gov> wrote:
Also what do you have for:
echo $PATH
which make
Retry wiht petsc-3.4.3 - and if you still have issues - send us configure.log
Satish
On Thu, 24 Oct 2013, Satish Balay wrote:
> On Thu, 24 Oct 2013, Qin Lu wrote:
> > Jed,
> > As I mentioned, I did add C:\cygwin64\bin (where make.exe is) to Path,
> You shouldn't have to do this. Perhaps cygwin is not setup properly.
> Also cygwin notation is /usr/bin - not C:\cygwin64\bin
> Are you running the commands in 'mintty' terminal or 'cmd' terminal?
> > and also tried to run ./configure --with-cc='win32fe icl' --with-fc='win32fe ifort' --with-cxx='win32fe icl' --with-make=/cygdrive/cygwin64/bin. It did not work, I just tried what you suggested: adding --download-make in confugure, it gave the same error.
> --download-make is not in petsc-3.4
> BTW: the latest patch update is petsc-3.4.3
> Satish
> > Thanks,
> > Qin
> > On Thursday, October 24, 2013 10:36 AM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> > Qin Lu <lu_qin_2000 at yahoo.com> writes:
> > > Hello,
> > > I am trying to build PETSc in Windows 7 with following steps:
> > > 1. Installed cygwin 64-bit with python, make and other default packages under C:\cygwin64
> > > 2. Added C:\cygwin64\bin to Windows environmental variable Path.
> > > 3. Downloaded and unzipped PETSc 3.4.2.
> > > 4. Run mintty.exe to open a cygwin terminal.
> > > 5. In the cygwin terminal, under PETSc directory, run: ./configure --with-cc='win32fe icl' --with-fc='win32fe ifort' --with-cxx='win32fe icl'
> > > However, it gave an error "Could not locate the make utility on your system, make sure it is in your path or use --with-make=/fullpathnameofmake and run ./configure again". I suppose it should use C:\cygwin64\bin\make.exe, which is already in path, but I still added --with-make=/cvgdrive/cygwin64/bin in configure's option and run configure again, yet it gave the same error.
> > You need to pass the full path to the make executable (or add it to your
> > path), or you can use --download-make.
> > > What should I do to let configure know the path of make?
> > > Many thanks for your help,
> > > Regard,
> > > Qin
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20131024/96cd4b89/attachment-0001.obj>
