[petsc-users] memory use of a DMDA
Wed Oct 23 09:20:20 CDT 2013
Juha Jäykkä <juhaj at iki.fi> writes:
>> I will test with 3.3 later today if I have the time, but I'm pretty sure
>> things were "better" there.
> I did happen to have one system still having 3.2 on it, so I tested that
> instead of 3.3 and at least 3.2 seems to be a bit more conservative in
> numbers. For the same $CMD as before, I get
> for x in 1 2 4 ; do mpirun -np $x python -c "$CMD"; done
> 21 MiB / 21868 kB
> 21 MiB / 21888 kB
> 218 MiB / 224028 kB
> 22 MiB / 22852 kB
> 22 MiB / 22600 kB
> 22 MiB / 22620 kB
> 22 MiB / 22872 kB
> 79 MiB / 81640 kB
> 79 MiB / 81372 kB
> 22 MiB / 22628 kB
> 22 MiB / 22648 kB
> 22 MiB / 22632 kB
> 22 MiB / 22652 kB
> 22 MiB / 22880 kB
> 22 MiB / 22900 kB
> 22 MiB / 22908 kB
> 22 MiB / 22928 kB
> 51 MiB / 52944 kB
> 51 MiB / 52936 kB
> 51 MiB / 53188 kB
> 51 MiB / 53216 kB
> For comparison, 3.4.2 gives (from the previous email): 354 MiB for 1
> rank, 141 for 2 ranks and 81 for 4 ranks, which is a LOT less. I
> suspect this might have something to do with the DA -> DMDA change?
Hmm, I wonder where you're getting your numbers from.
CMD='import psutil,os; rss = lambda: psutil.Process(os.getpid()).get_memory_info().rss; print rss()/2**20, "MiB initial"; from petsc4py import PETSc; print rss()/2**20, "MiB loaded petsc4py"; da = PETSc.DA().create(sizes=[100,100,100], proc_sizes=[PETSc.DECIDE,PETSc.DECIDE,PETSc.DECIDE], boundary_type=[3,0,0], stencil_type=PETSc.DA.StencilType.BOX, dof=7, stencil_width=1, comm=PETSc.COMM_WORLD); print rss()/2**20, "MiB DMDA"'
Here is what I have with v3.4.2, which is almost exactly the same as you
show above for v3.2.  In particular, it is much better than your email
claimed for v3.4.2.
  $ mpirun.hydra -np 1 python2 -c "$CMD"
  8 MiB /
  29 MiB
  226 MiB
  $ mpirun.hydra -np 2 python2 -c "$CMD"
  8 MiB initial
  8 MiB initial
  27 MiB loaded petsc4py
  77 MiB DMDA
  77 MiB DMDA
  $ mpirun.hydra -np 4 python2 -c "$CMD"
  8 MiB initial
  8 MiB initial
  8 MiB initial
  8 MiB initial
  53 MiB DMDA
  53 MiB DMDA
  53 MiB DMDA
  53 MiB DMDA
and with Barry's patch:
  8 MiB initial
  29 MiB loaded petsc4py
  172 MiB DMDA
  8 MiB initial
  8 MiB initial
  51 MiB DMDA
  51 MiB DMDA
  8 MiB initial
  8 MiB initial
  8 MiB initial
  8 MiB initial
  39 MiB DMDA
  39 MiB DMDA
  38 MiB DMDA
  39 MiB DMDA
The psutil package is in PyPI and most distributions.
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20131023/b1390f8f/attachment.pgp>
