[petsc-users] Fwd: How PETSc solves Ax=b in parallel
    Matthew Knepley
    knepley at gmail.com
    Mon Oct 21 11:53:15 CDT 2013
On Mon, Oct 21, 2013 at 11:23 AM, paul zhang <paulhuaizhang at gmail.com>wrote:
> Hi Jed,
> Thanks a lot for your answer. It really helps. I built parts of the matrix
> on each processor, then collected them into a global one according to their
> global position. Actually I used two MPI function instead of the one in the
> example, where the local size, as well as the global size is given.
> VecCreateMPI and MatCreateMPIAIJ. It does not really matter right?
> My continuing question is since the iteration for the system is global. Is
> it more efficient if I solve locally instead. ie. solve parts on each of
> the processor instead of doing globally.
No, because this ignores the coupling between domains.
  Matt
> Thanks again,
> Paul
> On Mon, Oct 21, 2013 at 11:42 AM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
>> paul zhang <paulhuaizhang at gmail.com> writes:
>> > I am using KSP, more specifically FGMRES method, with MPI to solve Ax=b
>> > system. Here is what I am doing. I cut my computation domain into many
>> > pieces, in each of them I compute independently by solving fluid
>> equations.
>> > This has nothing to do with PETSc. Finally, I collect all of the
>> > information and load it to a whole A matrix.
>> I hope you build parts of this matrix on each processor, as is done in
>> the examples.  Note the range Istart to Iend here:
>> http://www.mcs.anl.gov/petsc/petsc-current/src/ksp/ksp/examples/tutorials/ex2.c.html
>> > My question is how PETSc functions work in parallel in my case. There
>> are
>> > two guesses to me. First, PETSc solves its own matrix for each domain
>> using
>> > local processor, although A is a global. For the values like number of
>> > iterations, solution vector, their numbers should have equaled to the
>> > number of processors I applied, but I get only one value for each of
>> them.
>> > The reason is that the processors must talk with each other once all of
>> > their work is done, that is why I received the "all reduced" value.
>> This is
>> > more logical than my second guess.
>> It does not work because the solution operators are global, so to solve
>> the problem, the iteration must be global.
>> > In the second one, the system is solved in parallel too. But PETSc
>> function
>> > redistributes the global sparse matrix A to each of the processors after
>> > its load is complete. That is to say now each processor may not solve
>> the
>> > its own partition matrix.
>> Hopefully you build the matrix already-distributed.  The default
>> _preconditioner_ is local, but the iteration is global.  PETSc does not
>> "redistribute" the matrix automatically, though if you call
>> MatSetSizes() and pass PETSC_DECIDE for the local sizes, PETSc will
>> choose them.
> Huaibao (Paul) Zhang
> *Gas Surface Interactions Lab*
> Department of Mechanical Engineering
> University of Kentucky,
> Lexington,
> KY, 40506-0503*
> Office*: 216 Ralph G. Anderson Building
> *Web*:gsil.engineering.uky.edu
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20131021/4fabb718/attachment-0001.html>
