[petsc-users] Fwd: How PETSc solves Ax=b in parallel
paul zhang
paulhuaizhang at gmail.com
Mon Oct 21 11:23:11 CDT 2013
Hi Jed,
Thanks a lot for your answer. It really helps. I built parts of the matrix
on each processor, then collected them into a global one according to their
global position. Actually I used two MPI function instead of the one in the
example, where the local size, as well as the global size is given.
VecCreateMPI and MatCreateMPIAIJ. It does not really matter right?
My continuing question is since the iteration for the system is global. Is
it more efficient if I solve locally instead. ie. solve parts on each of
the processor instead of doing globally.
Thanks again,
Paul
On Mon, Oct 21, 2013 at 11:42 AM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> paul zhang <paulhuaizhang at gmail.com> writes:
> > I am using KSP, more specifically FGMRES method, with MPI to solve Ax=b
> > system. Here is what I am doing. I cut my computation domain into many
> > pieces, in each of them I compute independently by solving fluid
> equations.
> > This has nothing to do with PETSc. Finally, I collect all of the
> > information and load it to a whole A matrix.
> I hope you build parts of this matrix on each processor, as is done in
> the examples. Note the range Istart to Iend here:
> http://www.mcs.anl.gov/petsc/petsc-current/src/ksp/ksp/examples/tutorials/ex2.c.html
> > My question is how PETSc functions work in parallel in my case. There are
> > two guesses to me. First, PETSc solves its own matrix for each domain
> using
> > local processor, although A is a global. For the values like number of
> > iterations, solution vector, their numbers should have equaled to the
> > number of processors I applied, but I get only one value for each of
> them.
> > The reason is that the processors must talk with each other once all of
> > their work is done, that is why I received the "all reduced" value. This
> is
> > more logical than my second guess.
> It does not work because the solution operators are global, so to solve
> the problem, the iteration must be global.
> > In the second one, the system is solved in parallel too. But PETSc
> function
> > redistributes the global sparse matrix A to each of the processors after
> > its load is complete. That is to say now each processor may not solve the
> > its own partition matrix.
> Hopefully you build the matrix already-distributed. The default
> _preconditioner_ is local, but the iteration is global. PETSc does not
> "redistribute" the matrix automatically, though if you call
> MatSetSizes() and pass PETSC_DECIDE for the local sizes, PETSc will
> choose them.
Huaibao (Paul) Zhang
*Gas Surface Interactions Lab*
Department of Mechanical Engineering
University of Kentucky,
Lexington,
KY, 40506-0503*
Office*: 216 Ralph G. Anderson Building
*Web*:gsil.engineering.uky.edu
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20131021/138ba678/attachment.html>
