[petsc-users] Dense Matrix setting local rows / local columns	Question
    Jed Brown
    jedbrown at mcs.anl.gov
    Fri Oct 18 13:27:40 CDT 2013
James A Charles <charlesj at purdue.edu> writes:
> Actually I think I was wrong where it was occurring (I have several
> MatMatMults).
If you use the error checking macros (CHKERRQ), you'll get a full stack
trace on errors like that.
> The MatMatMult for sparse-dense seems to be working! The problem seems
> to be with dense-dense? I made sure of this by printing out the Matrix
> Type before calling the multiplication. Is dense-dense not supported?
Correct.  I thought you said your dense matrix had only a few columns.
What are you multiplying it with?
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20131018/d560bacf/attachment.pgp>
