[petsc-users] signal received error; MatNullSpaceTest; Stokes flow solver with pc fieldsplit and schur complement
Bishesh Khanal bisheshkh at gmail.com
Thu Oct 17 08:47:38 CDT 2013
On Thu, Oct 17, 2013 at 3:00 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> Bishesh Khanal <bisheshkh at gmail.com> writes:
> > The program crashes only for a bigger domain size. Even in the cluster,
> it
> > does not crash for the domain size up to a certain size.  So I need to
> run
> > in the debugger for the case when it crashes to get the stack trace from
> > the SEGV, right ? I do not know how to attach a debugger when submitting
> a
> > job to the cluster if that is possible at all!
> Most machines allow you to get "interactive" sessions.  You can usually
> run debuggers within those.  Some facilities also have commercial
> debuggers.
Thanks, I'll have a look at that.
> > Or are you asking me to run the program in the debugger in my laptop
> > for the biggest size ? (I have not tried running the code for the
> > biggest size in my laptop fearing it might take forever)
> Your laptop probably doesn't have enough memory for that.
Yes, I tried it just a while ago and this is happened I think. (Just to
confirm, I have put the error message for this case at the very end of this
reply.*)
> Can you try running on the cluster with one MPI rank per node?  We
> should rule out simple out-of-memory problems, confirm that the code
> executes correctly with MPICH, and finally figure out why it fails with
> Open MPI (assuming that the previous hunch was correct).
I'm sorry but I'm a complete beginner with MPI and clusters; so what does
one MPI rank per node means and what should I do to do that ? My guess is
that I set one core per node and use multiple nodes in my job script file ?
Or do I need to do something in the petsc code ?
*Here is the error I get when running for the full domain size in my laptop:
[3]PETSC ERROR: --------------------- Error Message
[3]PETSC ERROR: Out of memory. This could be due to allocating
[3]PETSC ERROR: too large an object or bleeding by not properly
[3]PETSC ERROR: destroying unneeded objects.
[1]PETSC ERROR: Memory allocated 0 Memory used by process 1700159488
[1]PETSC ERROR: Try running with -malloc_dump or -malloc_log for info.
[1]PETSC ERROR: Memory requested 6234924800!
[1]PETSC ERROR:
[1]PETSC ERROR: Petsc Release Version 3.4.3, Oct, 15, 2013
[1]PETSC ERROR: See docs/changes/index.html for recent updates.
[1]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
[1]PETSC ERROR: See docs/index.html for manual pages.
[1]PETSC ERROR:
[1]PETSC ERROR: [2]PETSC ERROR: Memory allocated 0 Memory used by process
1695793152
[2]PETSC ERROR: Try running with -malloc_dump or -malloc_log for info.
[2]PETSC ERROR: Memory requested 6223582208!
[2]PETSC ERROR:
[2]PETSC ERROR: Petsc Release Version 3.4.3, Oct, 15, 2013
[2]PETSC ERROR: See docs/changes/index.html for recent updates.
[2]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
[2]PETSC ERROR: See docs/index.html for manual pages.
[2]PETSC ERROR:
[2]PETSC ERROR: src/AdLemMain on a arch-linux2-cxx-debug named edwards by
bkhanal Thu Oct 17 15:19:22 2013
[1]PETSC ERROR: Libraries linked from
/home/bkhanal/Documents/softwares/petsc-3.4.3/arch-linux2-cxx-debug/lib
[1]PETSC ERROR: Configure run at Wed Oct 16 15:13:05 2013
[1]PETSC ERROR: Configure options --download-mpich
-download-f-blas-lapack=1 --download-metis --download-parmetis
--download-superlu_dist --download-scalapack --download-mumps
--download-hypre --with-clanguage=cxx
[1]PETSC ERROR:
[1]PETSC ERROR: PetscMallocAlign() line 46 in
/home/bkhanal/Documents/softwares/petsc-3.4.3/src/sys/memory/mal.c
src/AdLemMain on a arch-linux2-cxx-debug named edwards by bkhanal Thu Oct
17 15:19:22 2013
[2]PETSC ERROR: Libraries linked from
[2]PETSC ERROR: Configure run at Wed Oct 16 15:13:05 2013
[2]PETSC ERROR: Configure options --download-mpich
[2]PETSC ERROR:
[2]PETSC ERROR: PetscMallocAlign() line 46 in
[1]PETSC ERROR: MatSeqAIJSetPreallocation_SeqAIJ() line 3551 in
/home/bkhanal/Documents/softwares/petsc-3.4.3/src/mat/impls/aij/seq/aij.c
[1]PETSC ERROR: MatSeqAIJSetPreallocation() line 3496 in
[2]PETSC ERROR: MatSeqAIJSetPreallocation_SeqAIJ() line 3551 in
[2]PETSC ERROR: MatSeqAIJSetPreallocation() line 3496 in
[1]PETSC ERROR: MatMPIAIJSetPreallocation_MPIAIJ() line 3307 in
/home/bkhanal/Documents/softwares/petsc-3.4.3/src/mat/impls/aij/mpi/mpiaij.c
[1]PETSC ERROR: MatMPIAIJSetPreallocation() line 4015 in
[2]PETSC ERROR: MatMPIAIJSetPreallocation_MPIAIJ() line 3307 in
[2]PETSC ERROR: MatMPIAIJSetPreallocation() line 4015 in
[0]PETSC ERROR: --------------------- Error Message
[0]PETSC ERROR: Out of memory. This could be due to allocating
[0]PETSC ERROR: too large an object or bleeding by not properly
[0]PETSC ERROR: destroying unneeded objects.
[2]PETSC ERROR: [1]PETSC ERROR: DMCreateMatrix_DA_3d_MPIAIJ() line 1101 in
/home/bkhanal/Documents/softwares/petsc-3.4.3/src/dm/impls/da/fdda.c
[2]PETSC ERROR: DMCreateMatrix_DA() line 771 in
[3]PETSC ERROR: Memory allocated 0 Memory used by process 1675407360
[3]PETSC ERROR: Try running with -malloc_dump or -malloc_log for info.
[3]PETSC ERROR: Memory requested 6166659200!
[3]PETSC ERROR:
[3]PETSC ERROR: Petsc Release Version 3.4.3, Oct, 15, 2013
[3]PETSC ERROR: See docs/changes/index.html for recent updates.
[3]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
[3]PETSC ERROR: See docs/index.html for manual pages.
[3]PETSC ERROR:
[3]PETSC ERROR: src/AdLemMain on a arch-linux2-cxx-debug named edwards by
[3]PETSC ERROR: Libraries linked from
[3]PETSC ERROR: Configure run at Wed Oct 16 15:13:05 2013
[3]PETSC ERROR: Configure options --download-mpich
[3]PETSC ERROR:
[3]PETSC ERROR: [1]PETSC ERROR: DMCreateMatrix() line 910 in
/home/bkhanal/Documents/softwares/petsc-3.4.3/src/dm/interface/dm.c
[2]PETSC ERROR: DMCreateMatrix() line 910 in
[3]PETSC ERROR: MatSeqAIJSetPreallocation_SeqAIJ() line 3551 in
[3]PETSC ERROR: MatSeqAIJSetPreallocation() line 3496 in
[1]PETSC ERROR: KSPSetUp() line 207 in
/home/bkhanal/Documents/softwares/petsc-3.4.3/src/ksp/ksp/interface/itfunc.c
[2]PETSC ERROR: KSPSetUp() line 207 in
[3]PETSC ERROR: MatMPIAIJSetPreallocation_MPIAIJ() line 3307 in
[3]PETSC ERROR: MatMPIAIJSetPreallocation() line 4015 in
[3]PETSC ERROR: DMCreateMatrix_DA_3d_MPIAIJ() line 1101 in
[3]PETSC ERROR: DMCreateMatrix_DA() line 771 in
[3]PETSC ERROR: DMCreateMatrix() line 910 in
[3]PETSC ERROR: KSPSetUp() line 207 in
[1]PETSC ERROR: solveModel() line 128 in
"unknowndirectory/"/user/bkhanal/home/works/AdLemModel/src/PetscAdLemTaras3D.cxx
[2]PETSC ERROR: solveModel() line 128 in
[3]PETSC ERROR: solveModel() line 128 in
[0]PETSC ERROR: Memory allocated 0 Memory used by process 1711476736
[0]PETSC ERROR: Try running with -malloc_dump or -malloc_log for info.
[0]PETSC ERROR: Memory requested 6292477952!
[0]PETSC ERROR:
[0]PETSC ERROR: Petsc Release Version 3.4.3, Oct, 15, 2013
[0]PETSC ERROR: See docs/changes/index.html for recent updates.
[0]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
[0]PETSC ERROR: See docs/index.html for manual pages.
[0]PETSC ERROR:
[0]PETSC ERROR: src/AdLemMain on a arch-linux2-cxx-debug named edwards by
[0]PETSC ERROR: Libraries linked from
[0]PETSC ERROR: Configure run at Wed Oct 16 15:13:05 2013
[0]PETSC ERROR: Configure options --download-mpich
[0]PETSC ERROR:
[0]PETSC ERROR: PetscMallocAlign() line 46 in
[0]PETSC ERROR: MatSeqAIJSetPreallocation_SeqAIJ() line 3551 in
[0]PETSC ERROR: MatSeqAIJSetPreallocation() line 3496 in
[0]PETSC ERROR: MatMPIAIJSetPreallocation_MPIAIJ() line 3307 in
[0]PETSC ERROR: MatMPIAIJSetPreallocation() line 4015 in
[0]PETSC ERROR: DMCreateMatrix_DA_3d_MPIAIJ() line 1101 in
[0]PETSC ERROR: DMCreateMatrix_DA() line 771 in
[0]PETSC ERROR: DMCreateMatrix() line 910 in
[0]PETSC ERROR: KSPSetUp() line 207 in
[0]PETSC ERROR: solveModel() line 128 in
--9345:0:aspacem  Valgrind: FATAL: VG_N_SEGMENTS is too low.
--9345:0:aspacem    Increase it and rebuild.  Exiting now.
--9344:0:aspacem  Valgrind: FATAL: VG_N_SEGMENTS is too low.
--9344:0:aspacem    Increase it and rebuild.  Exiting now.
--9343:0:aspacem  Valgrind: FATAL: VG_N_SEGMENTS is too low.
--9343:0:aspacem    Increase it and rebuild.  Exiting now.
--9346:0:aspacem  Valgrind: FATAL: VG_N_SEGMENTS is too low.
--9346:0:aspacem    Increase it and rebuild.  Exiting now.
=   BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES
=   EXIT CODE: 1
=   CLEANING UP REMAINING PROCESSES
=   YOU CAN IGNORE THE BELOW CLEANUP MESSAGES
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20131017/105dc6ef/attachment.html>
