[petsc-users] cudaSetDevice
Wed Oct 9 06:48:08 CDT 2013
Karl Rupp <rupp at mcs.anl.gov> writes:
> What is a bit tricky is the question of *when* to call cudaSetDevice()
> then. We require users to call PetscInitialize() before anything else,
> so cudaSetDevice() needs to be called from some other place. I like the
> lazy instantiation model, where the GPU backends (OpenCL, CUDA) are
> initialized only when the first object (e.g. a Vec) is created.
This should also enable compiling libraries/binaries that support GPUs,
but then running on machines that don't have GPUs or don't have _enough_
for the number of MPI ranks you are using (provided you aren't making
GPU objects).  This is a very desirably property.
When at all possible, defer decisions to run-time when you have more
information about what is needed.
> I think this can be implemented fairly quickly - I'll do it unless
> there are any objections later today.
Thanks!
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20131009/217cbfb3/attachment.pgp>
