[petsc-users] cudaSetDevice
    Karl Rupp
    rupp at mcs.anl.gov
    Wed Oct  9 06:16:17 CDT 2013
 >> Perhaps one can do cudaGetDevice() and cudaDeviceReset() in between
the two
>> calls to PetscInitialize in the application code?
>> Provided no device data was allocated in between the two calls, this might
>> eliminate the error.
> Sure, but how will we actually share the device between libraries?  What
> if the other library was not PETSc, but something else, and they also
> called cudaSetDevice, but with a different default mapping strategy?
> We need an interface that handles this case.
Yes, I encountered similar user requests in ViennaCL.
What is a bit tricky is the question of *when* to call cudaSetDevice()
then. We require users to call PetscInitialize() before anything else,
so cudaSetDevice() needs to be called from some other place. I like the
lazy instantiation model, where the GPU backends (OpenCL, CUDA) are
initialized only when the first object (e.g. a Vec) is created. This
should provide enough room for all customizations of the CUDA
initizalization between PetscInitialize() and VecCreate(). I think this
can be implemented fairly quickly - I'll do it unless there are any
objections later today.
Best regards,
Karli
