[petsc-users] cudaSetDevice
Harshad Sahasrabudhe
hsahasra at purdue.edu
Tue Oct 8 18:55:30 CDT 2013
Hi Jed,
You are right, it doesn't if you use just one PETSc. In our case, we use 2 PETSc libraries (compiled separately, one each for complex and double). And in that case, when the second PETSc library is initialized, cudaSetDevice throws an error. I can't think of any way in which both the PETSc libraries could be initialized with CUDA on the same process.
Do you have any idea?
I can only think of turning CUDA off on one PETSc as a way to avoid this.
Harshad
----- Original Message -----
To: "Harshad Sahasrabudhe" <hsahasra at purdue.edu>, "Matthew Knepley" <knepley at gmail.com>
Cc: petsc-users at mcs.anl.gov
Sent: Thursday, September 26, 2013 8:37:36 PM
Subject: Re: [petsc-users] cudaSetDevice
Harshad Sahasrabudhe <hsahasra at purdue.edu> writes:
> Basically, PetscInitialize is called 2 times, the second time from
> libmesh.
It should not be.
$ git grep -C3 PetscInitialize src/base/libmesh.C
src/base/libmesh.C- // Check whether the calling program has already initialized
src/base/libmesh.C- // PETSc, and avoid duplicate Initialize/Finalize
src/base/libmesh.C- PetscBool petsc_already_initialized;
src/base/libmesh.C: ierr = PetscInitialized(&petsc_already_initialized);
src/base/libmesh.C- CHKERRABORT(libMesh::COMM_WORLD,ierr);
src/base/libmesh.C- if (petsc_already_initialized != PETSC_TRUE)
src/base/libmesh.C- libmesh_initialized_petsc = true;
src/base/libmesh.C-# else
src/base/libmesh.C- if (libmesh_initialized_petsc)
src/base/libmesh.C- {
src/base/libmesh.C: ierr = PetscInitialize (&argc, const_cast<char***>(&argv), NULL, NULL);
src/base/libmesh.C- }
src/base/libmesh.C-# endif
