[petsc-users] SlepcInitialize Segmentation Fault
Satish Balay
balay at mcs.anl.gov
Tue Oct 8 14:08:51 CDT 2013
Do you get this error with petsc examples or slepc examples?
Satish
On Tue, 8 Oct 2013, Sonya Blade wrote:
> DEar All,
> I'm receiving the segmentation fault during the program run and this happens exactly at the
> SlepcInitialize function and I've no idea on what can be wrong, the error messages produced
> from compiler is as shown below. Any clue on what is wrong?
> ORIGINAL CODE SNIPPET
> int main( int argc, char **argv )
> Vec v0,vec,vec1,*evec,gamma,vec_test,result_vec; /* initial vector */
> Mat B, C, K, M, eigen_mat; /* operator matrix */
> EPS eps; /* eigenproblem solver context */
> const EPSType type;
> PetscInt N,m=15,nev,max_size,row,column,test_int,g_row,g_col;
> PetscErrorCode ierr;
> PetscScalar eigen_r,eigen_i,test_scalar, *vector_array,*vec1arr;
> PetscReal norm;
> double value,test;
> int i,j, counter, counter2;
> FILE *myfile;
> SlepcInitialize(&argc,&argv,NULL,NULL);
> ERROR MESSAGES
> At D:\TEST_FOLDER_asus\PROJECTS\CBFortran\Slepc_C\Slepc_Subspace\main.c:24
> Program received signal SIGSEGV, Segmentation fault.
> In strncat () (C:\Windows\SysWOW64\msvcrt.dll)
> 217 /cygdrive/d/TEST_FOLDER_asus/petsc-3.4.2/src/sys/objects/options.c: No such file or directory.
> #2 0x0065f761 in PetscSetProgramName (name=0x7370652d <Address 0x7370652d out of bounds>) at /cygdrive/d/TEST_FOLDER_asus/petsc-3.4.2/src/sys/objects/options.c:217
> Debugger finished with status 0
