[petsc-users] Suggestions for code with dof >> 1 ?
Christophe Ortiz
christophe.ortiz at ciemat.es
Tue Oct 8 04:00:59 CDT 2013
On Tue, Oct 8, 2013 at 12:18 AM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> Barry Smith <bsmith at mcs.anl.gov> writes:
> >> - In this type of problem, which TS scheme is recommended ? TSARKIMEX ?
> > Beats me.
> ARKIMEX should give you a decent integrator with adaptive error control.
> Use '-ts_arkimex_type 1bee' to use backward Euler with an
> extrapolation-based error estimator.
Good to know. I tried TSBEULER but it has constant timestep.
-Is there any other TS with adaptive timestep ?
-With ARKIMEX, is there a way to control the timestep ? For instance, is it
possible to control the max factor between two successive timesteps (dt' =
factor*dt), in order to avoid rejections ?
- Is it possible to have Cranck-Nicholson with adaptive timestep ? I tried
TSCN but it seems timestep is constant.
- I also tried TSROSW. Seems to work quite well in some cases. How does it
compare to ARKIMEX ?
Christophe
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20131008/c7c681a6/attachment.html>
