[petsc-users] Installation Error
Sonya Blade sonyablade2010 at hotmail.com
Fri Oct 4 23:32:23 CDT 2013
Dear All,
I'm receiving the following errors when I'm trying to install the
the slepc library, I'm attaching the following error messages and content
of the configure.log file residing in slepc-3.4.2\arch-mswin-c-debug\conf folder
Here is the output from Cygwin terminal
noname at noname /cygdrive/d/TEST_FOLDER_asus/slepc-3.4.2
$ ./configure
Checking environment...
Checking PETSc installation...
ERROR: Unable to link with PETSc
ERROR: See "arch-mswin-c-debug/conf/configure.log" file for details
HERE IS THE CONTENT OF CONFIGURE.LOG FILE
Starting Configure Run at Sat Oct  5 06:59:54 2013
Configure Options: ./configure
Working directory: /cygdrive/d/TEST_FOLDER_asus/slepc-3.4.2
Python version:
2.7.5 (default, Aug 19 2013, 23:22:02)
[GCC 4.8.1]
make: /usr/bin/make
PETSc source directory: /cygdrive/d/TEST_FOLDER_asus/petsc-3.4.2
PETSc install directory: /cygdrive/d/TEST_FOLDER_asus/petsc-3.4.2/arch-mswin-c-debug
PETSc version: 3.4.2
PETSc architecture: arch-mswin-c-debug
SLEPc source directory: /cygdrive/d/TEST_FOLDER_asus/slepc-3.4.2
SLEPc install directory: /cygdrive/d/TEST_FOLDER_asus/slepc-3.4.2/arch-mswin-c-debug
SLEPc version: 3.4.2
#include "petscksp.h"
int main() {
Vec v; Mat m; KSP k;
PetscInitializeNoArguments();
VecCreate(PETSC_COMM_WORLD,&v);
MatCreate(PETSC_COMM_WORLD,&m);
KSPCreate(PETSC_COMM_WORLD,&k);
return 0;
make: Entering directory `/tmp/slepc-0HKYpc'
gcc -o checklink.o -c -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g3 -fno-inline -O0   -I/cygdrive/d/TEST_FOLDER_asus/petsc-3.4.2/include -I/cygdrive/d/TEST_FOLDER_asus/petsc-3.4.2/arch-mswin-c-debug/include -I/cygdrive/d/TEST_FOLDER_asus/petsc-3.4.2/include/mpiuni    -D__INSDIR__=./ checklink.c
gcc -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g3 -fno-inline -O0  -o checklink checklink.o  -L/cygdrive/d/TEST_FOLDER_asus/petsc-3.4.2/arch-mswin-c-debug/lib  -lpetsc -Wl,-rpath,/cygdrive/d/TEST_FOLDER_asus/petsc-3.4.2/arch-mswin-c-debug/lib -lflapack -lfblas -lX11 -lpthread -L/usr/lib/gcc/x86_64-pc-cygwin/4.8.1 -L/usr/x86_64-pc-cygwin/lib -lgfortran -lgfortran -lquadmath -lm -lstdc++ -lgdi32 -luser32 -ladvapi32 -lkernel32 -ldl -lgcc_s -ladvapi32 -lshell32 -luser32 -ldl
/cygdrive/d/TEST_FOLDER_asus/petsc-3.4.2/arch-mswin-c-debug/lib/libpetsc.a(fp.c.o):fp.c:(.rdata$.refptr._fe_dfl_env[.refptr._fe_dfl_env]+0x0): undefined reference to `_fe_dfl_env'
collect2: error: ld returned 1 exit status
makefile:2: recipe for target `checklink' failed
make: *** [checklink] Error 1
make: Leaving directory `/tmp/slepc-0HKYpc'
YOUR HELP WILL BE APPRECIATED,
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20131005/dd5af3a2/attachment.ksh>
