[petsc-users] Petsc-3.4.2 with MinGW-w64 on Windows 7
    Satish Balay
    balay at mcs.anl.gov
    Fri Oct  4 18:11:13 CDT 2013
On Thu, 3 Oct 2013, Mengda Wu wrote:
> Hi Satis,
>   I've tried to use mingw distributed with cygwin. And it worked well for
> static libraries.
>   Another problem I am facing is I cannot build shared libraries with it
> even I supplied with "--with-shared-libraries=1". Only .a libs are
> generated and there are no dlls.
Do you need dlls? Its possible [with some hacks] - but the fortran
side won't work.
> There was a message saying "CMake setup
> incomplete (status 256), falling back to legacy build" when configuring.
Hm - thats wierd.. cmake should generally work..
> I did install Cygwin's cmake. I don't know if cmake will help for shared
> libraries.
The general guidelines that can work - is:
- have cygwin cmake
- use the following patch for buildsystem to enable a flag for dll/sharedlibs
https://bitbucket.org/petsc/petsc/commits/50bcd979838a41ef30e4433272ba6c2e94f335bb
- configure  with --with-fc=0
- buit libraries making sure cmake is used.
Satish
> Thanks,
> Mengda
> On Wed, Oct 2, 2013 at 1:07 AM, Satish Balay <balay at mcs.anl.gov> wrote:
> > On Tue, 1 Oct 2013, Mengda Wu wrote:
> > > Hi Satish,
> > >    Thanks a lot for your reply!
> > >    Is there a way to use the mingw64 which is not shipped with cygwin?
> > For
> > > example, use windows native paths when testing the compiler.
> > Nope - I don't think it will work. Our build tools are primarily work with
> > cygwin paths.
> > Alternative is to use MS/Intel compilers - and we support them with
> > win32fe compiler wrapper.
> > What problem are you having with using mingw distributed with cygwin?
> > Satish
