[petsc-users] Petsc-3.4.2 with MinGW-w64 on Windows 7
Mengda Wu wumengda at gmail.com
Thu Oct 3 08:54:48 CDT 2013
Hi Satis,
  I've tried to use mingw distributed with cygwin. And it worked well for
static libraries.
  Another problem I am facing is I cannot build shared libraries with it
even I supplied with "--with-shared-libraries=1". Only .a libs are
generated and there are no dlls. There was a message saying "CMake setup
incomplete (status 256), falling back to legacy build" when configuring. I
did install Cygwin's cmake. I don't know if cmake will help for shared
libraries.
Mengda
On Wed, Oct 2, 2013 at 1:07 AM, Satish Balay <balay at mcs.anl.gov> wrote:
> On Tue, 1 Oct 2013, Mengda Wu wrote:
> > Hi Satish,
> >    Thanks a lot for your reply!
> >    Is there a way to use the mingw64 which is not shipped with cygwin?
> For
> > example, use windows native paths when testing the compiler.
> Nope - I don't think it will work. Our build tools are primarily work with
> cygwin paths.
> Alternative is to use MS/Intel compilers - and we support them with
> win32fe compiler wrapper.
> What problem are you having with using mingw distributed with cygwin?
> Satish
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20131003/fb31368a/attachment.html>
