[petsc-users] neumann failure in my version of snes ex12
Matthew Knepley
knepley at gmail.com
Sun Nov 24 18:10:29 CST 2013
On Sun, Nov 24, 2013 at 6:06 PM, Geoffrey Irving <irving at naml.us> wrote:
> On Sun, Nov 24, 2013 at 5:41 AM, Matthew Knepley <knepley at gmail.com>
> wrote:
> > On Sat, Nov 23, 2013 at 5:44 PM, Geoffrey Irving <irving at naml.us> wrote:
> >> On Sat, Nov 23, 2013 at 12:20 PM, Matthew Knepley <knepley at gmail.com>
> >> wrote:
> >> > On Sat, Nov 23, 2013 at 2:04 PM, Geoffrey Irving <irving at naml.us>
> wrote:
> >> >> On Sat, Nov 23, 2013 at 10:11 AM, Matthew Knepley <knepley at gmail.com
> >> >> wrote:
> >> >> > On Sat, Nov 23, 2013 at 12:07 PM, Geoffrey Irving <irving at naml.us>
> >> >> > wrote:
> >> >> >> On Sat, Nov 23, 2013 at 4:43 AM, Matthew Knepley <
> >> >> >> wrote:
> >> >> >> > On Fri, Nov 22, 2013 at 6:42 PM, Geoffrey Irving <
> irving at naml.us>
> >> >> >> > wrote:
> >> >> >> >> On Fri, Nov 22, 2013 at 4:25 PM, Matthew Knepley
> >> >> >> >> wrote:
> >> >> >> >> > On Fri, Nov 22, 2013 at 6:09 PM, Geoffrey Irving
> >> >> >> >> > <irving at naml.us>
> >> >> >> >> > wrote:
> >> >> >> >> >> On Fri, Nov 22, 2013 at 3:41 PM, Matthew Knepley
> >> >> >> >> >> wrote:
> >> >> >> >> >> > On Fri, Nov 22, 2013 at 5:36 PM, Geoffrey Irving
> >> >> >> >> >> > <irving at naml.us>
> >> >> >> >> >> > wrote:
> >> >> >> >> >> >> I have a duplicate of snes ex12 (FEM Poisson) which works
> >> >> >> >> >> >> with
> >> >> >> >> >> >> Dirichlet boundary conditions, but it's breaking for me
> >> >> >> >> >> >> with
> >> >> >> >> >> >> Neumann
> >> >> >> >> >> >> conditions. In particular, with Neumann conditions I get
> >> >> >> >> >> >> results
> >> >> >> >> >> >> which explode even though I believe I am setting a
> constant
> >> >> >> >> >> >> nullspace.
> >> >> >> >> >> >> For example, if I use two first order elements (the unit
> >> >> >> >> >> >> square
> >> >> >> >> >> >> divided into two triangles), the resulting solution has
> >> >> >> >> >> >> L2 error = 1.75514e+08
> >> >> >> >> >> >> u = [-175513825.75680602, -175513825.66302037,
> >> >> >> >> >> >> -175513825.48390722, -175513824.84436429]
> >> >> >> >> >> >> This looks rather a lot like the null space isn't getting
> >> >> >> >> >> >> through.
> >> >> >> >> >> >> I
> >> >> >> >> >> >> am creating the constant nullspace with
> >> >> >> >> >> >> MatNullSpace null;
> >> >> >> >> >> >> CHECK(MatNullSpaceCreate(comm(),PETSC_TRUE,0,0,&null));
> >> >> >> >> >> >> CHECK(MatSetNullSpace(m,null));
> >> >> >> >> >> >> CHECK(MatNullSpaceDestroy(&null));
> >> >> >> >> >> >> If I pass "-ksp_view -mat_view", I get the following.
> The
> >> >> >> >> >> >> matrix
> >> >> >> >> >> >> entries seem right (they do indeed have the constant
> >> >> >> >> >> >> nullspace),
> >> >> >> >> >> >> and
> >> >> >> >> >> >> ksp_view shows that a nullspace is attached. Is
> attaching
> >> >> >> >> >> >> the
> >> >> >> >> >> >> nullspace to the matrix with MatSetNullSpace enough, or
> do
> >> >> >> >> >> >> I
> >> >> >> >> >> >> need
> >> >> >> >> >> >> to
> >> >> >> >> >> >> additionally attach it to the KSP object?
> >> >> >> >> >> > 1) I always run with -ksp_monitor_true_residual now when
> >> >> >> >> >> > debugging.
> >> >> >> >> >> > This
> >> >> >> >> >> > can
> >> >> >> >> >> > give
> >> >> >> >> >> > you an idea whether you have a singular PC, which I
> >> >> >> >> >> > suspect
> >> >> >> >> >> > here.
> >> >> >> >> >> > 2) Can you try using -pc_type jacobi? I think ILU might go
> >> >> >> >> >> > crazy
> >> >> >> >> >> > on a
> >> >> >> >> >> > deficient matrix.
> >> >> >> >> >> Here are results with -ksp_monitor_true_residual -pc_type
> >> >> >> >> >> none:
> >> >> >> >> >> http://naml.us/random/laplace-rtol.txt # with -ksp_rtol
> >> >> >> >> >> 1e-5
> >> >> >> >> >> http://naml.us/random/laplace-atol.txt # with -ksp_atol
> >> >> >> >> >> 1e-5
> >> >> >> >> > Okay, if you have an inconsistent RHS I do not think that
> >> >> >> >> > true_residual
> >> >> >> >> > will work
> >> >> >> >> > since it uses the unprojected b, but the solve should be
> fine.
> >> >> >> >> I still don't understand why the atol version is able to drift
> so
> >> >> >> >> far
> >> >> >> >> away from zero mean, even after tens of thousands of
> iterations.
> >> >> >> >> If
> >> >> >> >> KSP sees a null space on the matrix, shouldn't it project that
> >> >> >> >> null
> >> >> >> >> space out of the *linear system* residual and also out of
> >> >> >> >> solution
> >> >> >> >> on
> >> >> >> >> each iteration? Even if it is only projecting out of the
> >> >> >> >> solution
> >> >> >> >> delta, how can null space errors be accumulating?
> >> >> >> > Both the KSP and Mat show that the null space is set, so
> >> >> >> > everything
> >> >> >> > should
> >> >> >> > work fine,
> >> >> >> > and at this point its no longer DMPlex that is in control, its
> >> >> >> > standard
> >> >> >> > PETSc.
> >> >> >> > We have reached the limit of usefu talking. Something is
> obviously
> >> >> >> > wrong
> >> >> >> > with the code,
> >> >> >> > but since this routinely works in PETSc examples. In situations
> >> >> >> > like
> >> >> >> > these I think we need
> >> >> >> > to follow the execution in the debugger to see what is
> wrong..You
> >> >> >> > can
> >> >> >> > look at Vec values
> >> >> >> > in the debugger using
> >> >> >> > (gdb) p ((Vec_Seq*) b-.data)->array[0]@v->map.n
> >> >> >> > and I look at DMPlex things with
> >> >> >> > (gdb) p ((DM_Plex*) dm->data)->coneSection
> >> >> >> > etc.
> >> >> >> Thanks, I appreciate the help. It looks like there were at least
> >> >> >> two
> >> >> >> different problems:
> >> >> >> 1. The boundary FE I was creating had the same dimension as the
> >> >> >> interior FE (instead of codimension 1), due to misreading ex12
> even
> >> >> >> though I had correctly refactored it. I added a dimension
> >> >> >> consistency
> >> >> >> check to my code, but I can do this in DMPlexComputeResidualFEM as
> >> >> >> well to catch future user errors.
> >> >> >> 2. Even after fixing the dimensions, my boundary functions in
> >> >> >> PetscFEM
> >> >> >> are getting x values both inside and completely outside the
> domain.
> >> >> >> Almost certainly more user error, but hopefully also something I
> can
> >> >> >> add a check for in petsc once I localize it.
> >> >> > This could be my bug. The test I have for ex12 is the variable
> >> >> > coefficient problem
> >> >> > with div (x + y) grad u = f. This seems to check between the
> analytic
> >> >> > and field
> >> >> > versions, meaning that the x coming into f1() matches the x I used
> to
> >> >> > make the
> >> >> > field, and my exact solution.
> >> >> It does seem to happen with stock snes ex12:
> >> >> branch: irving/assert-ex12-in-box1
> >> >> % mpiexec -host localhost -n 1
> >> >> /home/irving/petsc/debug/lib/ex12-obj/ex12 -run_type test
> >> >> -refinement_limit 0.0 -bc_type neumann -interpolate 1
> >> >> -petscspace_order 1 -bd_petscspace_order 1 -show_initial
> >> >> -dm_plex_print_fem 1 -dm_view ::ascii_info_detail
> >> >> [0]PETSC ERROR: evaluation at point outside unit box: 0 1.25
> >> >> I'll trace down why this is happening.
> >> > My first guess is a triangle with backwards edge. This could cause the
> >> > geometry routines to barf.
> >> I don't think it's edge orientation: it breaks (though at different
> >> points) regardless of whether I orient all the edges clockwise or
> >> counterclockwise. Also, I would expect bad edge orientation to result
> >> in bad normals but not to produce bad quadrature locations (nor bad
> >> residuals as long as the user routines don't depend on normal).
> >> Specifically, I think the problem is a sign error in
> >> DMPlexComputeProjection2Dto1D_Internal. The following patch seems to
> >> fix the out of bounds evaluation problem.
> >> DMPlexComputeProjection2Dto1D is computing a matrix which maps from
> >> the given segment to the canonical segment, and
> >> DMPlexComputeLineGeometry_Internal expects a map from the canonical
> >> segment to the given segment.
> >> snes ex12 passes with and without this change, presumably because the
> >> only Neumann test has constants along each box side, and is therefore
> >> invariant to this error.
> > When I replaced my kludge with code using the normal explicitly, I get
> the
> > same
> > error as you do. You fix is correct, and I checked it into
> > knepley/fix-fem-bd-integrate
> > https://bitbucket.org/petsc/petsc/branch/knepley/fix-fem-bd-integrate
> > along with other fixes that I think get Neumann all the way correct in
> ex12.
> >> Unfortunately, my Laplace test is also invariant to this error, so
> >> this bug is unrelated to the earlier problem.
> > It could be one of the other fixes I made. Could you run again?
> Much better. All the points and (inward) normals are right, and now
> my residuals have zero sum as expected. There's still something
> wrong, since I don't get the exact solution with second order
> elements, but that's probably an independent problem. I will trace it
> down. Thanks for the help and fixes!
> Why did you choose inward pointing normals, by the way? I would have
> though outward pointing normals are the nearly universal convention.
That is a bug fixed in that branch. Did you try next?
Thanks
Matt
> Geoffrey
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20131124/11b06c00/attachment-0001.html>
