[petsc-users] neumann failure in my version of snes ex12
Matthew Knepley
knepley at gmail.com
Sun Nov 24 07:41:44 CST 2013
On Sat, Nov 23, 2013 at 5:44 PM, Geoffrey Irving <irving at naml.us> wrote:
> On Sat, Nov 23, 2013 at 12:20 PM, Matthew Knepley <knepley at gmail.com>
> wrote:
> > On Sat, Nov 23, 2013 at 2:04 PM, Geoffrey Irving <irving at naml.us> wrote:
> >> On Sat, Nov 23, 2013 at 10:11 AM, Matthew Knepley <knepley at gmail.com>
> >> wrote:
> >> > On Sat, Nov 23, 2013 at 12:07 PM, Geoffrey Irving <irving at naml.us>
> >> > wrote:
> >> >> On Sat, Nov 23, 2013 at 4:43 AM, Matthew Knepley <knepley at gmail.com>
> >> >> wrote:
> >> >> > On Fri, Nov 22, 2013 at 6:42 PM, Geoffrey Irving <irving at naml.us>
> >> >> > wrote:
> >> >> >> On Fri, Nov 22, 2013 at 4:25 PM, Matthew Knepley <
> >> >> >> wrote:
> >> >> >> > On Fri, Nov 22, 2013 at 6:09 PM, Geoffrey Irving <
> irving at naml.us>
> >> >> >> > wrote:
> >> >> >> >> On Fri, Nov 22, 2013 at 3:41 PM, Matthew Knepley
> >> >> >> >> wrote:
> >> >> >> >> > On Fri, Nov 22, 2013 at 5:36 PM, Geoffrey Irving
> >> >> >> >> > <irving at naml.us>
> >> >> >> >> > wrote:
> >> >> >> >> >> I have a duplicate of snes ex12 (FEM Poisson) which works
> with
> >> >> >> >> >> Dirichlet boundary conditions, but it's breaking for me with
> >> >> >> >> >> Neumann
> >> >> >> >> >> conditions. In particular, with Neumann conditions I get
> >> >> >> >> >> results
> >> >> >> >> >> which explode even though I believe I am setting a constant
> >> >> >> >> >> nullspace.
> >> >> >> >> >> For example, if I use two first order elements (the unit
> >> >> >> >> >> square
> >> >> >> >> >> divided into two triangles), the resulting solution has
> >> >> >> >> >> L2 error = 1.75514e+08
> >> >> >> >> >> u = [-175513825.75680602, -175513825.66302037,
> >> >> >> >> >> -175513825.48390722, -175513824.84436429]
> >> >> >> >> >> This looks rather a lot like the null space isn't getting
> >> >> >> >> >> through.
> >> >> >> >> >> I
> >> >> >> >> >> am creating the constant nullspace with
> >> >> >> >> >> MatNullSpace null;
> CHECK(MatNullSpaceCreate(comm(),PETSC_TRUE,0,0,&null));
> >> >> >> >> >> CHECK(MatSetNullSpace(m,null));
> >> >> >> >> >> CHECK(MatNullSpaceDestroy(&null));
> >> >> >> >> >> If I pass "-ksp_view -mat_view", I get the following. The
> >> >> >> >> >> matrix
> >> >> >> >> >> entries seem right (they do indeed have the constant
> >> >> >> >> >> nullspace),
> >> >> >> >> >> and
> >> >> >> >> >> ksp_view shows that a nullspace is attached. Is attaching
> the
> >> >> >> >> >> nullspace to the matrix with MatSetNullSpace enough, or do I
> >> >> >> >> >> need
> >> >> >> >> >> to
> >> >> >> >> >> additionally attach it to the KSP object?
> >> >> >> >> > 1) I always run with -ksp_monitor_true_residual now when
> >> >> >> >> > debugging.
> >> >> >> >> > This
> >> >> >> >> > can
> >> >> >> >> > give
> >> >> >> >> > you an idea whether you have a singular PC, which I
> suspect
> >> >> >> >> > here.
> >> >> >> >> > 2) Can you try using -pc_type jacobi? I think ILU might go
> >> >> >> >> > crazy
> >> >> >> >> > on a
> >> >> >> >> > deficient matrix.
> >> >> >> >> Here are results with -ksp_monitor_true_residual -pc_type none:
> >> >> >> >> http://naml.us/random/laplace-rtol.txt # with -ksp_rtol
> 1e-5
> >> >> >> >> http://naml.us/random/laplace-atol.txt # with -ksp_atol
> 1e-5
> >> >> >> > Okay, if you have an inconsistent RHS I do not think that
> >> >> >> > true_residual
> >> >> >> > will work
> >> >> >> > since it uses the unprojected b, but the solve should be fine.
> >> >> >> I still don't understand why the atol version is able to drift so
> >> >> >> far
> >> >> >> away from zero mean, even after tens of thousands of iterations.
> If
> >> >> >> KSP sees a null space on the matrix, shouldn't it project that
> null
> >> >> >> space out of the *linear system* residual and also out of solution
> >> >> >> on
> >> >> >> each iteration? Even if it is only projecting out of the solution
> >> >> >> delta, how can null space errors be accumulating?
> >> >> > Both the KSP and Mat show that the null space is set, so everything
> >> >> > should
> >> >> > work fine,
> >> >> > and at this point its no longer DMPlex that is in control, its
> >> >> > standard
> >> >> > PETSc.
> >> >> > We have reached the limit of usefu talking. Something is obviously
> >> >> > wrong
> >> >> > with the code,
> >> >> > but since this routinely works in PETSc examples. In situations
> like
> >> >> > these I think we need
> >> >> > to follow the execution in the debugger to see what is wrong..You
> can
> >> >> > look at Vec values
> >> >> > in the debugger using
> >> >> > (gdb) p ((Vec_Seq*) b-.data)->array[0]@v->map.n
> >> >> > and I look at DMPlex things with
> >> >> > (gdb) p ((DM_Plex*) dm->data)->coneSection
> >> >> > etc.
> >> >> Thanks, I appreciate the help. It looks like there were at least two
> >> >> different problems:
> >> >> 1. The boundary FE I was creating had the same dimension as the
> >> >> interior FE (instead of codimension 1), due to misreading ex12 even
> >> >> though I had correctly refactored it. I added a dimension
> consistency
> >> >> check to my code, but I can do this in DMPlexComputeResidualFEM as
> >> >> well to catch future user errors.
> >> >> 2. Even after fixing the dimensions, my boundary functions in
> PetscFEM
> >> >> are getting x values both inside and completely outside the domain.
> >> >> Almost certainly more user error, but hopefully also something I can
> >> >> add a check for in petsc once I localize it.
> >> > This could be my bug. The test I have for ex12 is the variable
> >> > coefficient problem
> >> > with div (x + y) grad u = f. This seems to check between the analytic
> >> > and field
> >> > versions, meaning that the x coming into f1() matches the x I used to
> >> > make the
> >> > field, and my exact solution.
> >> It does seem to happen with stock snes ex12:
> >> branch: irving/assert-ex12-in-box1
> >> % mpiexec -host localhost -n 1
> >> /home/irving/petsc/debug/lib/ex12-obj/ex12 -run_type test
> >> -refinement_limit 0.0 -bc_type neumann -interpolate 1
> >> -petscspace_order 1 -bd_petscspace_order 1 -show_initial
> >> -dm_plex_print_fem 1 -dm_view ::ascii_info_detail
> >> [0]PETSC ERROR: evaluation at point outside unit box: 0 1.25
> >> I'll trace down why this is happening.
> > My first guess is a triangle with backwards edge. This could cause the
> > geometry routines to barf.
> I don't think it's edge orientation: it breaks (though at different
> points) regardless of whether I orient all the edges clockwise or
> counterclockwise. Also, I would expect bad edge orientation to result
> in bad normals but not to produce bad quadrature locations (nor bad
> residuals as long as the user routines don't depend on normal).
> Specifically, I think the problem is a sign error in
> DMPlexComputeProjection2Dto1D_Internal. The following patch seems to
> fix the out of bounds evaluation problem.
> DMPlexComputeProjection2Dto1D is computing a matrix which maps from
> the given segment to the canonical segment, and
> DMPlexComputeLineGeometry_Internal expects a map from the canonical
> segment to the given segment.
> snes ex12 passes with and without this change, presumably because the
> only Neumann test has constants along each box side, and is therefore
> invariant to this error.
When I replaced my kludge with code using the normal explicitly, I get the
same
error as you do. You fix is correct, and I checked it into
knepley/fix-fem-bd-integrate
https://bitbucket.org/petsc/petsc/branch/knepley/fix-fem-bd-integrate
along with other fixes that I think get Neumann all the way correct in ex12.
> Unfortunately, my Laplace test is also invariant to this error, so
> this bug is unrelated to the earlier problem.
It could be one of the other fixes I made. Could you run again?
Matt
> Geoffrey
> --- a/src/dm/impls/plex/plexgeometry.c
> +++ b/src/dm/impls/plex/plexgeometry.c
> @@ -213,8 +213,8 @@ static PetscErrorCode
> DMPlexComputeProjection2Dto1D_Internal(PetscScalar coords[
> const PetscReal r = sqrt(x*x + y*y), c = x/r, s = y/r;
> PetscFunctionBegin;
> - R[0] = c; R[1] = s;
> - R[2] = -s; R[3] = c;
> + R[0] = c; R[1] = -s;
> + R[2] = s; R[3] = c;
> coords[0] = 0.0;
> coords[1] = r;
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20131124/0d93c7c5/attachment-0001.html>
